Paul__B:
KenF:
Place the board that you've prepared into the dish of etching fluid. Since it's your first time it would be wise to have it face up. Be patient, this takes some time. Every so often you can rock it gently to dislodge any air bubbles on the surface of the board.It seems to me that either you have not actually etched a board yourself, or you are using an etchant very different to that I have used (Ferric Chloride). If you just let it sit or rock it gently nothing will happen except that the resist will eventually lift.
It is generally necessary to use a bubble etch system with an airstone at the bottom of the (vertical) tank evenly aerating the board, or agitate the board quite vigorously in the hot solution.
I've etched boards using ferric chloride, never had a bubbler or heater. Shallow plastic tray, copper side up, enough solution to cover and maybe again as much more, rocking that back and forth casually and constantly. Works pretty good, maybe 15 min as I recollect.
[But, I agree that its just laying there, "soaking", does no good.]
