// Module d'enregistrement de son IDS1760 autonome ou piloté par ARDUINO
// tiptopboards.com
// Code adapté de code: interfacing a chipcorder isd1760 - Interfacing - Arduino Forum
// Unsped 2008
// Modifs en français C Rolland 18 12 2013
// Broches Arduino utilisées
#define DATAOUT 11 //MOSI (bleu)
#define DATAIN 12 //MISO (vert)
#define SPICLOCK 13 //SCK (marron)
#define SLAVESELECT 10 //SS (rouge)
// Relier aussi les pins +5V et GND
// Codes de commandes de ISD1760 depuis l'Arduino
// Pour plus de détails voir ici http://www.electroniccircuits.gr/files/ISD1700.pdf
#define PU 0x01 //Power Up the device
#define STOP 0x02 //Stop the current operation
#define RESET 0x03 //Reset the device
#define CLR_INT 0x04 //Clear interrupt and OEM bit
#define RD_STATUS 0x05 //Return Returns status bits & current row counter in first 1st 2 bytes and operating status in 3rd byte
#define RD_PLAY_PTR 0x06 //Returns status bits & current row counter in 1st 2 bytes and Play pointer in 3rd & 4th bytes
#define PD 0x07 //Power Down
#define RD_REC_PTR 0x08 //Returns status bits & current row counter in 1st 2 bytes and Record pointer in 3rd & 4th bytes
#define DEVID 0x09 //Read the deivce ID register.
#define PLAY 0x40 //Play from current location without LED action until EOM or STOP command received
#define REC 0x41 //Record from current location without LED action until end of memory or STOP command received
#define ERASE 0x42 //Erase current message to EOM location
#define G_ERASE 0x43 //Erase all messages (not include Sound Effects)
#define RD_APC 0x44 //Returns status bits & current row counter in first 1st 2 bytes and the contents of APC register in 3rd & 4th bytes.
#define WR_APC1 0x45 //Write the data D10:D0 into the APC register with volume setting from VOL pin
#define WR_APC2 0x65 //Write the data D10:D0 into the APC register with volume setting from bits D2:D0
#define WR_NVCFG 0x46 //Write the contents of APC to NVCFG
#define LD_NVCFG 0x47 //Load contents of NVCFG to APC Register
#define FWD 0x48 //Forward play pointer to start address of next message. Forward will be ignored during operating, except Play
#define CHK_MEM 0x49 //Check circular memory
#define EXTCLK 0x4A //Enable/disable external clock mode
#define SET_PLAY 0x80 //Play from start address S10:S0 to end address E10:E0 or stop at EOM, depending on the D11 of APC
#define SET_REC 0x81 //Record from start address to end address E10:E0
#define SET_ERASE 0x82 //Erase from start address S10:S0 to end address E10:E0 [Stop cmd is ignored]
// Configuration des 4 pins de commande
byte clr;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); //disable device
SPCR = B01111111; //data lsb, clock high when idle, samples on falling
clr=SPSR;
clr=SPDR;
delay(10);
//Moniteur série
digitalWrite(SLAVESELECT,LOW); //Mettre le module en route
spi_transfer(PU); // Power Up
spi_transfer(0x00); // data byte
delay(100);
Serial.println("Power Up");
digitalWrite(SLAVESELECT,LOW); //Clear
spi_transfer(CLR_INT); // Clear interupt and EOM bit
delay(100);
Serial.println("Clear");
// Lire un son enregistré dans la mémoire flash puis passe au suivant, en boucle
spi_transfer(PLAY); // PLAY écouter le son pointé par le curseur
Serial.println("PLAY");
ready_wait(); //Attendre la fin de ce son
delay(3000);
spi_transfer(FWD); // Décaler le curseur au son suivant
Serial.println("FWD");
// Fonction ready_wait
void ready_wait(){
byte byte1;
byte byte2;
byte byte3;
//Pour savoir si le son est terminé, tester le 1er bit du 3eme octet MISO
while(byte3<<7 != 128){
byte1 = spi_transfer(RD_STATUS);
// Returns status bits & current row counter in first 1st 2 bytes
// and operating status in 3rd byte
byte2 = spi_transfer(0x00); // data byte
byte3 = spi_transfer(0x00); // data byte
delay(100);
} //Fin de la fonction
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait for the end of the transmission
return SPDR; // return the received byte
