Can anyone, please, tell me how to put a degree symbol on the oled screen using the u8g lib?
I have scoured the internet and found all kinds of "solutions" but non just worked for me.
With U8g2:
A suitable font could be u8g2_font_helvB12_tf
You can see the degree symbol at 0x0b0, which is also the official unicode position.
Oliver
Thanks for replying, Oli!
I did come that far, but could not combine this piece of information with the code. Probably simple, when you know how. So, please, can you show me a piece of code incorporating the 176/0x0b0 resulting in printing the ° on the Oled screen?
Thanks in advance.
I believe u8g.print (char(176)); should work if the chosen is tf.
ASCII Version:
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.setFont(u8g2_font_helvB12_tf);
u8g2.setFontDirection(0);
u8g2.firstPage();
do {
u8g2.setCursor(0, 15);
u8g2.print("-1 \xb0C");
} while ( u8g2.nextPage() );
UTF8 Version:
void setup(void) {
u8g2.begin();
u8g2.enableUTF8Print(); // enable UTF8 support for the Arduino print() function
void loop(void) {
u8g2.firstPage();
do {
u8g2.print("-1 °C");
The advantage of the UTF8 version is, that you can directly type the degree symbol from your keyboard.
Oliver
Thanks both of you.
Later today I will do some coding and try to implement your suggestions.
Thanks again,
Thanks guys, I have it running! Now I can concentrate on the real program.
It is possible to display degree symbol using the u8g library too.
I used the font "u8g_font_7x14B" to do it.
u8g.setFont(u8g_font_7x14B);
u8g.setPrintPos(20, 20);
u8g.print(tValue);
u8g.write(0xB0);
where tValue is a temperature value like
float tValue = 32.19;
