i am trying to flash boot-loader on ATmega328 using Arduino Nano.
I have done the connection as follows
Arduino Pin 13 -> chip pin 19.
Arduino Pin 12 -> chip pin 18.
Arduino Pin 11 -> chip pin 17.
Arduino Pin 10 -> chip pin 1 Reset
i m using 8MHz crystal and 22pf capacitor connected on pin 9 and 10.
Here part of boards.txt file i have added.
uno328.name=Arduino328
uno328.upload.protocol=arduino
uno328.upload.maximum_size=32256
uno328.upload.speed=57600
uno328.bootloader.low_fuses=0xff
uno328.bootloader.high_fuses=0xde
uno328.bootloader.extended_fuses=0x05
uno328.bootloader.path=optiboot
uno328.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
uno328.bootloader.unlock_bits=0x3F
uno328.bootloader.lock_bits=0x0F
uno328.bootloader.tool=arduino:avrdude
uno328.build.mcu=atmega328
uno328.build.f_cpu=8000000L
uno328.build.core=arduino
uno328.build.variant=standard
atmega328bb.name=ATmega328(8 MHz internal clock)
atmega328bb.upload.protocol=arduino
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
atmega328bb.build.variant=arduino:standard
atmega328bb.bootloader.tool=arduino:avrdude
atmega328bb.upload.tool=arduino:avrdude
Both configuration is not working.
I am getting following error after trying to flash bootloader.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): unknown response=0x12
Error while burning bootloader.
Connected 10uf capacitor between VCC and GND also.
And my arduino ide version is 1.8.8.
Any help will be appreciated...
