Geekcreit® DUE R3 32 Bit ARM With USB Cable Arduino Compatible
3.2 Inch ILI9341 TFT LCD Display Module Touch Panel For Arduino
CTE TFT LCD / SD Card Shield For Arduino DUE Support 32Pin 40Pin Version LCD
(I'm new to this but I have UNO and Mega2560 that works for me with my other TFT screen and LCD)
I use Arduino IDE 1.8.5 to upload an example under File, Examples, TFT_HX8357_Due, TFT_Meter_4. The file uploads without error message but I'm not getting anything on screen except a white light. This is the same on all the examples I have tried.
I've check the DUE by uploading the basic example 'Blink' and it works. So, the board is fine. The screen has display on it (white light), so I believed it is a good display. The TFT shield powers the screen, so I think it is also good.
I started doing this not too long ago so I'm totally new to this stuff. I hope my explanation is good enough.
Or the DUE could just be faulty, the blink sketch does not and cannot check that each and every pin on the DUE is fully working. The pins needed to drive the display may not be connected, have bad solder joints etc.
Same as above really, it might go white, but that does not mean it will always accept commands from the Arduino .
Or the shield is faulty (see above) in that there is problems with the wiring for the control signals needed to control the display.
The problem with trying to get 3 things to work together, and they do not, is that its very difficult to work out from the outside which of the 3 bits is the problem.
I would start by trying another of the same type of display, but from a different source, its unlikely the same specific fault exists on two seperate displays.
Why are you attempting to use a library for the HX8357/ILI9481 with display that has an ILI9341?
While I'm not a fan of the library, have you tried UTFT which supports the hardware combination you have? You've got to start with software that is known to work with your hardware...
Thanks for the input guys. I've test each one to isolate the problem as per srnet and discovered the screen is defective. To avr_fred, I don't know how I came up using HX8357/ILI9481 :-). Anyway, thanks again for the quick response.
