I've done this in the past. It worked to a degree, but this is a tricky area
Some pseudo-code in here - as it refers to project specific variables...
Call this when you initially startup, and again later if the network fails for any reason, call it again
bool usingDHCP, weWantoUseDHCP;
bool networkAvailable = false;
bool connect_to_network(void) {
usingDHCP = false; // assume the worst
if (weWantoUseDHCP) {
Serial.print("DHCP... ");
// DHCP timeout is set in Dhcp.h - note uppercase D
if (Ethernet.begin(myMAC_address) != 0) {
Serial.print("OK ");
usingDHCP = true;
Serial.print("not responding. ");
if (!usingDHCP) { // DHCP not in use, or failed to init
Serial.print("Use STATIC IP... ");
Ethernet.begin( myMAC_address, mySTATIC_IP, mySTATIC_NS, mySTATIC_GW, mySTATIC_NM);
networkAvailable = true;
return true;
