TomGeorge:
Yes you can leave the neutral disconnected.
But make sure Earth is used.Do you have an Electrician to help you with the 3phase wiring?
Will this be wired in to a switchboard or plug into a 5 pin 3phase outlet.
Do you plan to phase control the heater supply or just switch it ON and OFF around a setpoint?
Thanks.. Tom...
Yes I will have a certified electrician for wiring. plugged into a 5 pin 3phase outlet. planning for only on and off around set point as that has worked well with the single phase system so far.
