Hi everybody, It´s the first time I post in this forum (not in a forum) and since I have been using this huge knowledge database, I thought it was time for me to share something of what I´ve learn so far.
First of all, I began with the official arduino starter kit, making almost all practice in the book in a single day, I bought it because a weird idea came to my mind (now that I have researched that idea seems weirder and more crazy), and suddenly I won in a biddin a 6axis servo arm, with servos, a uno clon, adafruit 16servo shield and 2 extras (still working on moving the arm, do not ask about extras)
But stop with that, recently I got a sainsmart 8 RGB led module, I was amazed that its brigther than the usual RGB leds, my first code (that did not work at first time) turn on and off each led, first in 1 coor, then mixing 2 and finally the 3 to give a white light
wiring is as following:
UNO-----Sainsmart
5v ------- VCC (I think its beter to connect to an external supply and connect both 0v together)
2 ------- D1
3 ------- D2
4 ------- D3
5 ------- D4
6 ------- D5
7 ------- D6
8 ------- D7
9 ------- D8
10 ------- R
11 ------- G
12 ------- B (mine had swapped G & B)
For this module to work, you need to set to LOW the output of the led you want to turn ON, and LOW to the color pin you want the led to become, its kinda tricky specially when you´re used to PLCs with sinking inputs and sourcing outputs
the code is as follows:
int rgb[3];
int led[8];
int i = 0;
int j = 0;
int k = 0;
k = 2;
for (i = 0; i < 8; i++) {
led[i] = k;
k++;
pinMode(led[i], OUTPUT);
digitalWrite(led[i], HIGH);
k = 10;
for (i = 0; i < 3; i++) {
rgb[i] = k;
k++;
pinMode(rgb[i], OUTPUT);
digitalWrite(rgb[i], HIGH);
k = 0;
//R
digitalWrite(rgb[0], LOW);
roulette();
//G
digitalWrite(rgb[0], HIGH);
digitalWrite(rgb[1], LOW);
roulette();
//B
digitalWrite(rgb[1], HIGH);
digitalWrite(rgb[2], LOW);
roulette();
//GB
roulette();
//RG
digitalWrite(rgb[2], HIGH);
roulette();
//RB
roulette();
//RGB
roulette();
//OFF
void roulette() {
digitalWrite(led[i], LOW);
delay(300);
speed can be changed with the delay in the void roulette()
I think this code can be used with individual RGB leds, just connecting togheter all R´s, G´s and B´s and switching between the commons, but something tell mes the code will need some adjustments (like swapping the LOWs for HIGHs and viceversa)
Later, I was like, why I dont use PWM to mix colors? and also, lets learn something about multidimensional arrays, so I ended with another code, but I had to use this time a Mega since I wanted to control 8 pwm outputs,
same wiring as previous
and code (just ignore commented lines)
//declaring pins
int rgb[3];
int led[8];
//declaring aux variables
int i = 0;
int j = 0;
int k = 0;
int val;
//declaring da´array
int rgbArray[8][3] = {
{0, 255, 255},
{0, 0, 255},
{255, 0, 255},
{255, 0, 0},
{255, 255, 0},
{0, 255, 0},
{0, 0, 0},
{220, 55, 197}
//initializing led pins
k = 2;
led[i] = k;
k++;
//initializing color pins
k = 10;
rgb[i] = k;
k++;
i = 0;
j = 0;
k = 0;
writer();
//randomizer();
void writer() {
analogWrite(led[0], rgbArray[0][i]);
analogWrite(led[1], rgbArray[1][i]);
analogWrite(led[2], rgbArray[2][i]);
analogWrite(led[3], rgbArray[3][i]);
analogWrite(led[4], rgbArray[4][i]);
analogWrite(led[5], rgbArray[5][i]);
analogWrite(led[6], rgbArray[6][i]);
analogWrite(led[7], rgbArray[7][i]);
switcher();
delay(5);
i++;
if (i == 3) {
i = 0;
void switcher() {
if (i == 0) {
if (i == 1) {
if (i == 2) {
void randomizer() {
for (int i = 0; i < 8; i++) {
for (int j = 0; j < 3; j++) {
rgbArray[i][j] = int(random(255));
/*void printer() {
Serial.print("I=");
Serial.println(i);
Serial.print("J=");
Serial.println(j);
Serial.print("val=");
Serial.println(val);
firs I wanted to make a nested For loop to switch the analogWrite, something like
for(i=0;i<3;i++){
for(j=0;j<8;j++){
val=Array[i][j];
analogWrite(pin[i],val);
but not only got confused my self, the leds would blink a lot, and a stable color couldnt be seen, so I used that less elaborated code, I erased the 4 (just rewrited) non working sketches, If I find the right time, I will try to rewrite them, since the lights seemed nice for a disco night 8)
Hope you get the chance to test it sometime, I need to sleep right now, some PNP PLCs awaits me in the morning
Greetings from Mexico
