This is my first time ever using Arduino so I apologize in advance if this one is a no-brainer. I have a MKR1000 (WINC 1501 model B) which I'm trying to connect to my Wifi network and am having issues. When I run the CheckWifi101FirmwareVersion example it always returns with the following result:
WiFi101 firmware check.
WiFi101 shield: DETECTED
Firmware version installed: 19.5.2
Latest firmware version available : 19.5.4
Check result: NOT PASSED
The firmware version on the shield do not match the
version required by the library, you may experience
issues or failures.
The highest firmware version I can install within the Firmware Updater is 19.5.2 so I'm not able to update to 19.5.4 easily. Is there another way I can install firmware 19.5.4 that a beginner can understand? Also is this firmware incompatibility the reason I currently cannot run a sketch that connects to my Udibots account?
I was able to update to wifi101 19.5.4 by downloading the Arduino hourly IDE build. Now that I am using 19.5.4 I was able to successfully upload the WiFi101 example sketch to connect to WEP.
However, now I am having the issue that my MKR1000 is not connecting to my SSID. Just keeps trying to connect every 10 seconds.
Load the sketch from the wifi101 examples into the board called "FirmwareUpdater"
The board may (not always) now appear on a new com port that will be OK.
Select the WiFi101 Firmware Updater option and in there select the correct COM port and then TEST CONNECTION.
It should now work and you can update the firmware from there
It was mentioned that the latest firmware can only be uploaded with IDE 1.8.2 and that not all boards can accept the very latest depending on board revisions.
I use a WiFi Shield model B and an update to 19.5.2 was possible.
But I can not select the firmware 19.5.4 from the dropdown box in the WiFi Fireware/Certificates Updater.
Maybe be more specific as "WiFi" shields come in a large variety and you did not mention it was an MKR version.
However if I remember correctly the firmware update was not applicable to the shield version.
You would have to check that by doing a search in this section to be sure.
