In this way, Arduino boards can be connect to my home WiFi network. It's taking automatic IP from my network. But I don't want this. Iwant, this system must be work like Access Point. So, I can write any IP to the codes. Is that possible? If yes, can you send any example codes please? Thanks.
Which WiFi Shield is it. You can post a link to the product page.
notrino:
It's not clear what you mean by that. Are you wanting the Arduino to provide an access point (AP) initially, which serves a configuration web page where the user can set the IP address for connection to the network, or are you wanting to always run the Arduino as an AP and never connect to the external network?
Wow, we don't see the OG Arduino WiFi Shield much anymore. I'm not familiar with that hardware so I can't answer your question. Hopefully, someone else here has experience with it.
There is a popular library for ESP8266 that does (2). Although you won't be able to use it directly with your WiFi Shield, the code might provide a helpful reference:
The ESP8266WiFi library is based loosely on the API of the Arduino WiFi library, but with some necessary differences. So your code is likely to look fairly similar.
