pert:
You didn't really answer either of my questions.
Most importantly:Which hardware package are you using?
Woah, old school! Did you make that?
Why would you use that? The EEPROMex is completely obsolete and even worse you're using an outdated version of the library.
1, no, i don't use MightyCore,
2. yes, very old school..
3. what the best or newest library for use Eeprom for Programming Atmega32 ?
The Arduino IDE doesn't have built-in support for an ATmega32-based board. So you must have done something to add support for the ATmega32. So tell me what you did and then I can answer your question.
the led used for sign when my development board working with my code;
and upload to Uno. the result work perfectly in Uno.
Next, I try to upload using programmer to gelatino -32 w/Atmega32 with USBasp.
Then the chip move to my development board, and led light normally, but the program can't read or write internal eeprom, the variable value still zero;
