I need a little motor driver to drive a small motor at high PWM and found this little guy. Once I'm done prototyping, I'll be adding it to my own custom board. I'll only use 1 of the 2 h-bridges, though. So would it be good to connect the 3 input pins (BIN1, BIN2, BPWM) to ground, or leave them unconnected. I don't see any remark about it in the data sheet.
I have some Pololu DRV8833 drivers and I just leave the unused pins unconnected.
...R
The TB6612 can be driven as a parallel pair. Just wire all the inputs to the same Arduino pins and the outputs can be wired together. Then you get twice the current capability.
MorganS:
You can do the same with the DRV8833 but I don't need it.
...R
