MS5541 depth sensor communication
You really should consider creating functions to reduce memory e.g. reset()
Pressure is wrong and increases with every new measurement. Any thoughts?
Can you post a sequence of values you got?
Is the difference between two consecutive readings (nearly) constant ?
Formulas in the code are "quite complex" but I see no reason in the code.
Can it be that the sensor does not reset properly?
