I worked with NodeMCU esp8266 boards and i have option to upload sketch remotely by upload bin file to web server that run on the NodeMCU (My MCU projects are on the internet and i have connection to the mcu only by IP Address)
with libraries:
<WiFiClient.h>
<ESP8266WebServer.h>
<ESP8266HTTPUpdateServer.h>
Now i have Arduino MKR WiFi 1010 (Better MCU than NodeMCU and more expensive) that work with WiFiNINA library and i didn't found any solution for doing the same thing
"Upload sketch remotely by web server uploading"
Can you send me the information how to do it with command line ?
upload from IDE is not an option for me because the mcu is not on the same network subnet like my pc with IDE, and i know that IDE OTA is only works on the same network subnet and not by manual IP or maybe i`m wrong ?
I tried to run the command and this is the results
Connecting to board ... done
Uploading sketch ... done
Flashing sketch ... done
Error flashing the sketch:
How can i know why i get the Error ?
is there any log file ?
I used WiFi101_OTA.ino from the examples and change the WiFi101 library with the WiFiNINA library (i think this is the recommended library for MKR WiFi 1010)
RapidL:
it happens. What version of the upload tool do you have?
add some timestamp or versioning in the sketch to see if it was updated
