Well, I just got my first adruino today, and I am trying to get it set up to begin my first project. I have run into a problem trying to install the driver in order to communicate and upload to the uno. (I am running windows 7, 64 bit)
I was following the main beginners guide on this website, located here: http://arduino.cc/en/Guide/Windows
When I go to install the driver, it appears to be installing something, then I get the following error:
Windows found driver software for your device but encountered an error while attempting to install it.
Arduino UNO
The system cannot find the file specified.If you know the manufacturer of your device, you can visit its website and check the support section for the driver software.
If i do it again, it goes straight to the error without the screen that looks like its being productive. After a reboot, it again went to the screen where it looked promising again.
Before anyone says it, cause i know its coming from trying to find a solution on google-
I did give it the right directory (and after that failed i tried the two parent folders and the sub folder that its not supposed to be in)
the directory i put in is as follows: C:\Users\John\Downloads\arduino-0022\arduino-0022\drivers
I can see a file with the correct name there, it just isnt being loaded for some reason. (Arduino UNO.inf)
I also checked things out with the problem in the troubleshooting with the missing registry key on windows XP that was causing a very similar problem, and the registry key appears to be in tact on my system, but I dont generally play with that sort of thing, so I didnt do anything more than see that it was there. (http://forums.techguy.org/1680041-post1.html and http://arduino.cc/forum/index.php/topic,53042.0.html)
Going to see if I have better luck on my laptop,
any insight would be greatly appreciated!
