Topic: How to connect two devices to same SPI line (TPIC6B595 + LCD ST7920) (Read 369 times) previous topic - next topic
sn4k3
I'm trying to connect the shift register TPIC6B595 and LCD ST7920 to the SPI line to spare some pins.
But when both connected none will work, if i disconnect one or another it work alone. Obvious because they are connected to same lines without any pre selection. I'm not sure how to use SPI yet, the I2C are lot easier since it work with addresses, but what about the SPI? I read somewhere it need a EN (Pin enable or selector) but not sure how to wire or program this since the shift register haven't EN pin.
Is it possible to wire this both together?
Code sample:
#include <SPI.h>
#include <U8g2lib.h>
#define LCD_RESET      9  //reset
U8G2_ST7920_128X64_1_HW_SPI lcd(U8G2_R2, SCK, LCD_RESET); //Enable, RW, RS, RESET
  pinMode (SS, OUTPUT);
SPI.begin(); // library takes care of D11,12,13
lcd.firstPage();
  do {
    lcd.setFont(u8g2_font_unifont_t_symbols);
    lcd.drawStr(8, 16, "Smoke Absorver");
    lcd.drawStr(16, 36, "Version: 10");
    lcd.drawFrame(0, 0, 128, 64);
    lcd.drawFrame(2, 2, 124, 60);
  } while (lcd.nextPage());
// say 4 devices being used
digitalWrite (SS,LOW);  // SS (D9)goes to SRCK PIN on all devices
SPI.transfer(B00000001);  // SCK (D13) goes to clock pin on all devices
digitalWrite (SS,HIGH);  // outputs update on this rising edge
SPI.transfer(B00000100);  // SCK (D13) goes to clock pin on all devices
Delta_G
Have you been here yet?    https://www.arduino.cc/en/Reference/SPI  Your answer is within.
Along with a lot more information that you might need soon.
If at first you don't succeed, up - home - sudo - enter.
sn4k3
I have but theres one thing that still confuse me
SS (Slave Select) - the pin on each device that the master can use to enable and disable specific devices.
If i have to use the SS pin to disable and enable devices to comunicate with, and atmega328p only have one SS pin that mean i can only control 1 device without any other parts like a decoder?
Delta_G
No, you gotta actually read the whole page.  You can't just read the first little bit and think you have it figured out.
Read down to the section labelled Note About Slave Select pin on AVR based boards.   Last paragraph before the examples.  But don't just read that one bit to get this answer.  Read the whole page.  It's full of info you'll need.
sn4k3
Thank you for point me out.
I have changed my code and wiring, still i got same effect but now shift register won't work  :(
Have changed shift register G to D9 and LCD EN to D8.
LCD backlight keep blinking without any text (caused by loop)
What i'm doing wrong?
#include <SPI.h>
#define LCD_RESET      8  //reset
U8G2_ST7920_128X64_1_HW_SPI lcd(U8G2_R2, SCK, LCD_RESET); //Rotation, Clock, RESET
  pinMode (9, OUTPUT);
digitalWrite (9,LOW);  // SS (D9)goes to SRCK PIN on all devices
digitalWrite (9,HIGH);  // outputs update on this rising edge
 lcd.firstPage();
  do {
    //lcd.setFont(u8g2_font_ncenB14_tr);
    //lcd.drawStr(0, 24, "Smoke Absorver " VERSION " ");
Delta_G
You have to give them all different SS pins.   Each device needs it's own pin for SS.  If you still think you only have one option for SS, then go read that again.
sn4k3
no, i have given different pins now
LCD SS -> SS
Shift Register SS -> 7
Can be that way? Because is not working to me
sn4k3
ok i able to fix it, belive or not i haven't tie the arduino GND to breadboard GND line, strange fact is that LCD had backlight and LED blink when tied to breadboard GND, hows that possible if all conections to GND was not connected?
