Problems with PLX DAQ
Hi there!
I'm having trouble with the software, the interface says it is connected but there is no data coming to the excel
const int flexPin0 = A0; //pin A0 to read analog input
char string0 = 'W';
//Variables:
int value0; //save analog value
void setup(){
  Serial.begin(9600);       //Begin serial communication
  Serial.println("LABEL,Sensor value");
void loop(){
  value0 = analogRead(flexPin0);         //Read and save analog value from potentiometer
  Serial.println(value0);               //Print value
  delay (1000);
Can somebody help?
Try inserting this line......it's described in the manual
  Serial.print("DATA,");
Thanks!
But now I have another problem regarding the naming of columns.
By default it shows Date Time Timer Counter and Millis
When I place this in setup
void setup(){
// while the serial stream is not open, do nothing:
while (!Serial)
    // do nothing
  Serial.println("CLEARDATA");
  Serial.println("LABEL,A,B,C, D,E");
The column name does not change but the values enter into excel one by one
When I place it at loop
void loop(){
  //Serial.print("DATA,TIME,TIMER");
  delay (1000);
The column name changes but the data keeps on replacing itself.
Pls help.
P/S: The (!serial) is because I use Leonardo
Label should be placed in setup.
GijKieken:
Can you help out?
I doubt if you have done the effort on reading the beginners guide.
Net-Devil has done a great job on this.
