So I'm using Arduino Mega 2560 with Ethernet Shield connected to a router and module Sim800 to receive call (and end it). But somehow this code doesn't work when I send Call command from PC:
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <String.h>
char data[3];
String command;
String senddata;
byte mac[] = {0x90, 0xA2, 0xEA, 0x01, 0x97, 0x10};
IPAddress ip(10, 0, 0, 4);
IPAddress myDns(10, 0, 0, 1);
IPAddress gateway(10, 0, 0, 1);
IPAddress subnet(255, 0, 0, 0);
unsigned int localPort = 8888; // local port to listen on
unsigned int sendPort = 12800;
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
EthernetUDP Udp;
while(!Serial);
Serial1.begin(9600);
while(!Serial1);
Ethernet.begin(mac, ip, myDns, gateway, subnet);
Udp.begin(localPort);
Serial.println("Setup Complete!");
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i = 0; i < 4; i++) {
Serial.print(remote[i], DEC);
if (i < 3) {
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
command = packetBuffer;
if(command == "Cal"){
for (int i = 0; i < 40000; i++){
char t[4];
String c;
if(Serial1.available()){
c = Serial1.readString();
Serial.println(c);
t[0] = c[2];
if (t[0] == 'R'){
Serial1.println("ATH");
Udp.beginPacket(Udp.remoteIP(), sendPort);
Udp.write("SUCCESS");
Udp.endPacket();
i = 39999;
else if (i == 39998) {
Udp.write("FAIL");
Udp.endPacket();
delay(1);
if(command == "Chk"){
Udp.write("OK");
Udp.endPacket();
I can see the Cal command sent to Arduino. But when I made call it doesn't hang up or print out anything to Serial Monitor.
