//Music led
int value = 0; // variable to keep the actual value
int ledPin[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13}; // light connected to digital pin 9
int val;
int n=0;
int time;
int NewVal;
int NewTime;
#define sensorRight 0
#define sensorLeft 1
int sensor
int oldMusicLeft=512;
int oldMusicRight=512;
for(int k=0;k<=13;k+=1)
pinMode(ledPin[k], OUTPUT);
int checkVal(sensor)
val=analogRead(sensor);
if((450<=val)&&(val<=550))
NewVal=0;
return NewVal;
if(val<=620)
NewVal=map(val,50,620,0,7);
return NewVal;
if(val>=516)
NewVal=map(val,620,1050,0,7);
return NewVal;
//int greaterValue(oldMusic, newMusic)
// if(newMusic<=oldMusic) //if the old value is greater
// for(n=oldMusic;n>=newMusic;n-=1) //turn lights to newMusic
// digitalWrite(n,LOW);
// delay(30);
// return yes=1;
// return yes=0;
void zero(int oldMusic, int newMusic)
int count;
if(count==10)
oldMusic=550;
newMusic=550;
return;
if((oldMusic<=(newMusic + 5))&&(oldMusic>=(newMusic-5)))
count=count+1;
return;
count=0;
return;
int newMusicLeft;
int newMusicRight;
int oldMusicLeft=520;
int oldMusicRight=520;
for(;
newMusicLeft=checkVal(sensorLeft);
newMusicRight=checkVal(sensorRight);
zero(oldMusicLeft, newMusicLeft);
zero(oldMusicRight, newMusicRight);
if(newMusicLeft<=oldMusicLeft) //if the old value is greater
for(n=oldMusicLeft;n>=newMusicLeft;n-=1) //turn lights to newMusic
if(newMusicRight<=oldMusicRight) //if the old value is greater
for(n=oldMusicRight;n>=newMusicRight;n-=1) //turn lights to newMusic
if(newMusicLeft>=oldMusicLeft) //if the level is higher
for(int n=oldMusicLeft;n<=newMusicLeft;n+=1)
digitalWrite(n,HIGH);
delay(30);
if(newMusicRight>=oldMusicRight) //if the level is higher
for(n=oldMusicRight;n<=newMusicRight;n+=1)
delay(30);
oldMusicLeft=newMusicLeft;
oldMusicRight=newMusicRight;
delay(10);
This is my code and every time that I try and compile it I get the error message:
error: expected initializer before 'void'
I have no idea why this is giving me this error message. Any input would be wonderful. Thanks
