Hi.
Has anyone got the Arduino-MemoryFree to run?
I am using in my project a mkr1010, and after a while, the orange led starts blinking. I want to check if there is any memory leak, or something like that. But I can't go on with any MemAllocatin function I find in the Web.
Here, they say that the Arduino-MemoryFree works with SAMD21, but I could not get it work in my sketch.
Every time I call the freeRam() function, I got a compile error.
Arduino: 1.8.10 (Windows 10), Board: "Arduino MKR WiFi 1010"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\zampa\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\zampa\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\zampa\sketchbook\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0X2341_0X8054 -ide-version=10810 -build-path C:\Users\zampa\AppData\Local\Temp\arduino_build_940807 -warnings=all -build-cache C:\Users\zampa\AppData\Local\Temp\arduino_cache_763117 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\zampa\sketchbook\mi_10_03_mqtt_230char_withMemCheck\mi_10_03_mqtt_230char_withMemCheck.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\zampa\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\zampa\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\zampa\sketchbook\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0X2341_0X8054 -ide-version=10810 -build-path C:\Users\zampa\AppData\Local\Temp\arduino_build_940807 -warnings=all -build-cache C:\Users\zampa\AppData\Local\Temp\arduino_cache_763117 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\zampa\sketchbook\mi_10_03_mqtt_230char_withMemCheck\mi_10_03_mqtt_230char_withMemCheck.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Using core 'arduino' from platform in folder: C:\Users\zampa\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Detecting libraries used...
"C:\\Users\\zampa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\zampa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\zampa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\zampa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\zampa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\mkrwifi1010" "C:\\Users\\zampa\\AppData\\Local\\Temp\\arduino_build_940807\\sketch\\mi_10_03_mqtt_230char_withMemCheck.ino.cpp" -o nul
The compile message is quite long, and exceeds the 9000char limit.
