Hello,
Been struggling with this for a while now.
I'm trying to create a function like:
unsigned int setDigit(unsigned int inputNumber, byte newDigit, byte loc, byte exponent)
It should basically accept an unsigned int, a byte, a location and the exponent. It should then update whatever number is at location loc to the newDigit byte that's passed in.
I'm using this on a display 4x7 segment display that will show a number either in dec or hex (hence the exponent parameter) and the user can change a single digit that's being displayed by pressing a button to move the "cursor" left or right, and then press a number on a keypad to set that digit.
I do have a semi working version of this code, but having problems dealing with the edge cases. For example, when the address is 0 all my logic fails.
I've tried breaking the number up into a string and setting the index to the passed byte, but this also fails.
Here are my 2 attempts at it:
Non-string version:
unsigned int setDigit(unsigned int inputNumber, byte newDigit, byte loc, byte exponent) {
const byte maxSize = 32;
byte numberSize = (inputNumber == 0 ? 1 : 0);
unsigned int nSize = inputNumber;
while (nSize != 0 && numberSize < maxSize) {
nSize /= exponent;
numberSize++;
if (loc > maxSize || loc > numberSize || loc < 0) {
return inputNumber;
char *numberArray = calloc((int)numberSize, sizeof(char));
unsigned int i = 0;
unsigned int nCount = inputNumber;
while (nCount != 0 && i < numberSize) {
numberArray[i] = nCount % exponent;
nCount /= exponent;
i++;
numberArray[loc] = (newDigit % exponent);
int output = 0;
for (byte j = 0; j < numberSize; j++) {
output = exponent * output + numberArray[j];
if (numberArray) {
free(numberArray);
return output;
String version:
String inputString = "";
if (loc > maxSize || loc < 0) {
if (SERIAL_ERRORS && Serial) {
Serial.print("\nsetDigit(): Error: Index out of bounds.\n");
return inputNumber;
char temp[maxSize] = {0};
sprintf(temp, "%d", inputNumber);
inputString.concat(temp);
char replaceNum[maxSize] = {0};
sprintf(replaceNum, "%01d", (newDigit % exponent));
inputString[loc] = replaceNum;
unsigned int output = 0;
output = strtol(inputString.c_str(), NULL, exponent + 1);
return output;
