Alright, that helps, thank you.
Here's another issue, though.
I have a rotary encoder attached to a motor in this program. I want it to continue to rotate the motor until it reaches a certain pre-defined value. I have read up on the rotary encoder setups for the arduino, and I understand them, but I have a question about interrupts.
While it seems to make them more efficient, will it effect my code if it works as follows:
while( varA != varB)
//Send analog pulse to speed-controller
Then, the interrupts would force the program to use the predefined functions specified in the program. In those functions, I increment or decrement varA based on the direction of the encoder. "varB" is a value that I am trying to reach for the encoder. Would it still be able to compare varA and varB while the encoder functions are running, however?
I can explain this better if it's not clear.
