Tx and Rx can be confusing indeed because it's ambiguous. I rather use Txo (transmit output) and Rxi (receive input).
But I can't help you with the right pins in your setup. Connecting a Rxi to another Rxi is no problem. But a Txo to a Txo can give you a short.
So, like I said, start by echoing to the PC (without BlueTooth bs). What I would do is:
- Only cut a single data line (yellow or green)
- Display end to Rx2
- Controller end to Rx3
- Run a program like:
Serial2.begin(9600); // Display DP-C18 @TX16 RX17
Serial3.begin(9600); // Bafang Ultra Motor @TX14 RX15
Serial.begin(115200); //Computer, fast :)
readDisplay();
readController();
void readController() {
if (Serial3.available()) {
Serial.print("C/3: ")
Serial.println(Serial3.read());
void readDisplay() {
if (Serial2.available()) {
Serial.print("D/2: ")
Serial.println(Serial2.read());
Now you should only see data on Serial2 or on Serial3. The one you see data on is connected right (aka the Arduino Rxi is connected to the device Txo).
