I am using ArduinoMega 2560 as a sensor node for my project and raspberry pi 3 as data Coordinator. I am trying to make them communicate via Xbee Pro radios series1. Now I can communicate Xbee From XCTU from PC to raspberry pi3 but not with Arduino mega. Could anyone help me out, please? I am using XBee shield to connect Arduino with XBee PRO series1.
I have uploaded this program to Arduino which is connected Xbee pro by using Xbee Shield:
#! /usr/bin/python
from xbee import XBee
import serial
PORT = '/dev/ttyUSB0'
BAUD_RATE = 9600
# Open serial port
ser = serial.Serial(PORT, BAUD_RATE)
# Create API object
xbee = XBee(ser,escaped=True)
# Continuously read and print packets
while True:
try:
print "waiting"
response = xbee.wait_read_frame()
print response
except KeyboardInterrupt:
break
ser.close()
I can communicate Xbee pro1 with XCTU from PC to Raspberry pi3 but not with Arduino Could anyone help me out, please ?
The next questions I ask because I may need to replicate your setup.
Your using an Arduino Mega2560
Is the Mega2560 a clone or an original Arduino Mega2560?
Which Version of Arduino IDE are you using?
What operating system?
Linux, MacOSX, MS Windows, other
What Version of Raspbian is the Raspberry Pi 3 running?
Which XBee shield are you using?
I have several XBee shields from different vendors.
Please re post the sketch using the proper code tags and formatted for the forums using the Arduino IDE.
Do you have a block diagram of your project?
I have everything to probably replicate your setup.
I am using Arduino mega 2560 original.
I am using Raspberry pi 3 Model B and using NOOBS operating system which contains raspbian downloaded from this site [u]Raspberry Pi OS – Raspberry Pi
Arduino IDE- 1.8.5
XBee radios - XBee Pro 60mW Wire Antenna - Series 1 (802.15.4)
Arduino Xbee shield- ZigBee/XBee module shield V3.0 bought from the site [u]https://www.geeetech.com/zigbeexbee-module-shield-v30-p-565.html[/u]
Operating system - Windows 7 were my Arduino is connected with one Xbee pro(coordinator) with the shield.
Raspbian Os- Raspberrpi pi is connected to a sperate monitor where Xbee Pro(router) is connected via USB.
Okay, i had to update Digi Internaltion XCTU on my laptops.
How is the Raspberry PI 3 connected to the Xbee pro radio series 1?
How do you have the Xbee Pro Series 1 Radio Configured?
I have the Arduino Mega2560 with an Arduino Wireless Shield with the Xbee Pro Series 1 radio.
I have an Arduino Leonardo with another Arduino Wireless Shield with another Xbee Pro Series 1 Radio.
Just need the Raspberry Pi 3 with the Xbee connected.
I will post photographs later .
I have:
3 Xbee series 1 radios
3 Xbee Pro Series 1 radios
2 Xbee Series 2 radios
I am using Xbee PRO series1 and I have configured them by using XCTU software which was downloaded from Digi International. I have also got Xbee FTDI breakout board for configuring XBee module with XCTU software.
I used to connect Xbee PRO series1 to Raspberry pi3 using USB cable, not with Jumper wires.
Is there a possibility that there would be a problem with Arduino Xbee shield v3? Would that be a reason why they are unable to communicate?
jisha:
Thanks!
When you used XCTU to configure the Xbee what did you configure them?
Do you understand what I am asking?
I am not sure that you oo.
I can not do anything until you tell me how you configured the xbee modules with XCTU.
