Hi, I just got my Elegoo Uno R3 today and I'm not quite sure how to program it. Do I select the normal Arduino Uno in the IDE? Do I have to download any external things? Thanks.
(deleted)
spycatcher2k:
What does Elegoo say?
What does their advert say it is?
Why have you not just tried it!
Sorry,
I have tried uploading the sketch "blink" to the board using the setting for Arduino/Genuino Uno, but it doesn't work and gives me the message "Problem uploading to board see http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. Elegoo say nothing about programming the board anywhere.
Thanks.
Check you port ensure you have your port selected
I have this same problem and am still unsure how to go about programming it. I have gone ahead and bought
another microcontroller- namely the Arduino Uno R3-- and now I have a robotic kit waiting to programmed. Any help would be GREATLY appreciated!
same problem here. I just finished to build the Elegog car V3 yesterday for my kid. but I'm not able to upload the demo sample. The upload always fail.
BN: Arduino/Genuino Uno
VID: 2341
PID: 0043
SN: 5573530343435101F0B2
I have Windows 10, I see the Uno R3 in the device manager (com3). I selected the right ports in the arquino ide (version 1.8.4) and here the output los
Archiving built core (caching) in: C:\Users\sebas\AppData\Local\Temp\arduino_cache_87137\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 1122 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\sebas\AppData\Local\Temp\arduino_build_725833/forward_back.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x28
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I FOUND the solution.
in the word file.. there is thisat the step 7. REMOVE THE BLUETHOOT receiver each time you want to program.
and it works.
which file do i have to remove?
just got elegoo uno R3 wont connect any help what am i doing wrong?
biogh
