grazie mille per le risposte, ho provato inizialmente con il microfono, sono riuscito a fargli leggere delle frequenze ma non era assolutamente utilizzabile per il mio progetto, troppa confusione.
Allora ho preso questo piezo:
utilizzando questo sketch, da modificare poi una volta ottenuti risultati decenti (non sono un programmatore, trovo qualcosa di già fatto, cerco di capirlo e lo modifico in base alle mie esigenze):
* Modified Arduino Frequency Detection
* by Nicole Grimwood
* For more information please visit:
* https://www.instructables.com/id/Arduino-Guitar-Tuner/
* Slightly edited version of:
* Arduino Frequency Detection
* created October 7, 2012
* by Amanda Ghassaei
* This code is in the public domain.
//clipping indicator variables
boolean clipping = 0;
//data storage variables
byte newData = 0;
byte prevData = 0;
unsigned int time = 0;//keeps time and sends vales to store in timer[] occasionally
int timer[10];//storage for timing of events
int slope[10];//storage for slope of events
unsigned int totalTimer;//used to calculate period
unsigned int period;//storage for period of wave
byte index = 0;//current storage index
float frequency;//storage for frequency calculations
int maxSlope = 0;//used to calculate max slope as trigger point
int newSlope;//storage for incoming slope data
//variables for decided whether you have a match
byte noMatch = 0;//counts how many non-matches you've received to reset variables if it's been too long
byte slopeTol = 3;//slope tolerance- adjust this if you need
int timerTol = 10;//timer tolerance- adjust this if you need
//variables for amp detection
unsigned int ampTimer = 0;
byte maxAmp = 0;
byte checkMaxAmp;
byte ampThreshold = 50;//raise if you have a very noisy signal
void setup(){
pinMode(13,OUTPUT);//led indicator pin
pinMode(12,OUTPUT);//output pin
cli();//diable interrupts
//set up continuous sampling of analog pin 0 at 38.5kHz
//clear ADCSRA and ADCSRB registers
ADCSRA = 0;
ADCSRB = 0;
ADMUX |= (1 << REFS0); //set reference voltage
ADMUX |= (1 << ADLAR); //left align the ADC value- so we can read highest 8 bits from ADCH register only
ADCSRA |= (1 << ADPS2) | (1 << ADPS0); //set ADC clock with 32 prescaler- 16mHz/32=500kHz
ADCSRA |= (1 << ADATE); //enabble auto trigger
ADCSRA |= (1 << ADIE); //enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); //enable ADC
ADCSRA |= (1 << ADSC); //start ADC measurements
sei();//enable interrupts
ISR(ADC_vect) {//when new ADC value ready
PORTB &= B11101111;//set pin 12 low
prevData = newData;//store previous value
newData = ADCH;//get value from A0
if (prevData < 127 && newData >=127){//if increasing and crossing midpoint
newSlope = newData - prevData;//calculate slope
if (abs(newSlope-maxSlope)<slopeTol){//if slopes are ==
//record new data and reset time
slope[index] = newSlope;
timer[index] = time;
time = 0;
if (index == 0){//new max slope just reset
PORTB |= B00010000;//set pin 12 high
noMatch = 0;
index++;//increment index
else if (abs(timer[0]-timer[index])<timerTol && abs(slope[0]-newSlope)<slopeTol){//if timer duration and slopes match
//sum timer values
totalTimer = 0;
for (byte i=0;i<index;i++){
totalTimer+=timer[i];
period = totalTimer;//set period
//reset new zero index values to compare with
timer[0] = timer[index];
slope[0] = slope[index];
index = 1;//set index to 1
noMatch = 0;
else{//crossing midpoint but not match
if (index > 9){
reset();
else if (newSlope>maxSlope){//if new slope is much larger than max slope
maxSlope = newSlope;
time = 0;//reset clock
noMatch = 0;
index = 0;//reset index
else{//slope not steep enough
noMatch++;//increment no match counter
if (noMatch>9){
reset();
if (newData == 0 || newData == 1023){//if clipping
clipping = 1;//currently clipping
Serial.println("clipping");
time++;//increment timer at rate of 38.5kHz
ampTimer++;//increment amplitude timer
if (abs(127-ADCH)>maxAmp){
maxAmp = abs(127-ADCH);
if (ampTimer==1000){
ampTimer = 0;
checkMaxAmp = maxAmp;
maxAmp = 0;
void reset(){//clean out some variables
noMatch = 0;//reset match couner
maxSlope = 0;//reset slope
void checkClipping(){//manage clipping indication
if (clipping){//if currently clipping
clipping = 0;
void loop(){
checkClipping();
if (checkMaxAmp>ampThreshold){
frequency = 38462/float(period);//calculate frequency timer rate/period
//print results
Serial.print(frequency);
Serial.println(" hz");
delay(100);
però dal serial monitor ottengo il valore "clipping" oppure "inf hz" e non capisco se sbaglio dalla parte elettronica o da quella software...
