I cannot get the software to finish a compilation. I always get the following messages: I've tried to uninstall and reinstall but it does not clear the problem.
c:\program files (x86)\arduino\hardware\tools\avr\bin../lib/gcc/avr/5.4.0/../../../../avr/bin/ar.exe: unable to rename 'core\core.a'; reason: File exists
exit status 1
Error compiling for board Arduino Nano.
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
How can I delete the offending "core.a" file?
I hope someone can help as both my Windows 10 computer have the same problem.
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on. If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
There are at least 3 AV's out there known to be too aggressive.
But if you think logically it makes sense as you are essentially writing CODE that the AV may not fully understand. So it makes a judgement call in favour of your security.
