Hey !
I'd like to control a stepper motor (working at 2.8V and 2A/phase) with a A4988, I have a 12V 5A external power supply to power everything.
I found a lot of threads showing how to control the current you give to the motor but not about the voltage.
So here is my question:
Can I reduce the voltage (12V) of my power supply to 2.8V for my stepper motor ?
Can it be handled on the board or must I buy a buck converter ?
Thx !
You regulate the voltage by regulating the current. There's a little pot on the board to do just that. Remember to add a heat sink if you want more than 1A of current.
The A4988 is a sort of buck converter. That is why we love it. You don't need to add any components.
The voltage to the stepper is not relevant. The current to the coils is relevant. An A4988 controls the current (as set by the user). Even with a heat sink and fan cooling, 2A is on the ragged edge for for an A4988.
Hey, thanks for your answers that helped me out !
I choose an other stepper motor:
- it's cheaper,
- has the same torque for smaller,
- is 1.7A (further from the A4988 limit),
- is 12V.
Thx !
I hope you realise the nonsensical ratings the seller gives you?
1.7A current. Sensible.
30Ω winding resistance. Well, sounds a bit high but within the realm of possibilities.
12V supply. Unusual for steppers that are indeed current driven.
But... since when does 30 * 1.7 equal 12?
Ant_Wan_Kenobi:
Hey !
You don't control the voltage, you control the current. There's no way you can control both, the load won't cooperate.
No, it won't work, the A4988 needs at least 8V to function at all.
Thx !
Absolutely nothing needs doing. You might want to increase the supply voltage for better performance, however.
wvmarle:
I hope you realise the nonsensical ratings the seller gives you?1.7A current. Sensible.
12V supply. Unusual for steppers that are indeed current driven.But... since when does 30 * 1.7 equal 12?
Yes, I made myself the same reflexion...
What would you suggest ? Should I look for an other stepper motor with correct ratings ?
I've learned to ignore the nonsense written in e-bay and similar ads, instead look up the datasheet of the part.
wvmarle:
Turned out the 1.7 Amps were actually 0.4 Amps.
The stepper motor's ref was hidden on a picture: 42SHD0001-24B.
Looked on an other website that had the same motor and turns out its current is 0.4A (0.4*30 = 12).
Thx !
This are much more typical stepper specifications: coil resistance 2.1Ω and rated current 1.33A, that comes to a voltage of 2.8V which is also very typical for steppers.
And that's also why they're rated 5-24V and you need a stepper driver (which acts like a buck converter, using the stepper's coil instead of a fixed inductor). Without stepper driver the coils would indeed burn out pretty quickly.
