system
March 9, 2011, 1:58pm
1
Hi all,
I've just recived my Arduino Uno, i plugged it in my Pc (Win 7), and when I try to upload something this is what i get:
Binary sketch size: 1026 bytes (of a 32256 byte maximum)
avrdude: ser_open(): can't set com-state for "\\.\COM17"
I tried to change the COM port but it won't work...
The green Led is on
The L Led is still blinking as normaly...
I tried to search on Google but i haven't found a solution
Could you help me?
EDIT: on another pc (Win 7) it works, but i'd rather use this one...
GaryP
March 9, 2011, 8:41pm
2
Did you check the typical first thing; what com-port appears to the list when you connect your arduino? Double check that, and try again.
Cheers,
Kari
system
March 10, 2011, 8:29pm
3
Yes, I double checked it but still not working...
GaryP
March 10, 2011, 8:56pm
4
You have lots of serial drivers in your computer...?
Kari
system
March 10, 2011, 9:20pm
5
in the device manager i have only the Arduino Uno device... but in arduino program i can choose between COM4 to COM17 ports...
GaryP
March 10, 2011, 9:23pm
6
Ok, if you are sure that COM17 comes and goes when you connect and disconnect your arduino, then it must be so.
Cheers,
Kari
system
March 10, 2011, 9:31pm
7
the first COM that appeared in the device manager was COM3, but in arduino program i can only choose from COM4 to 17, so i changed it in the device manager...
did i do something wrong?
GaryP
March 10, 2011, 9:47pm
8
In all my Arduino IDE in four computers, I can see only those ports that can be seen in device manager. I have XP and Windows 7 64-bit, all works alike.
You shouldn't need to change com-port numbers without a good reason.
You say that you can't see COM3 in Arduino IDE even if that is the one that pops in and out in Windows device manager?
Cheers,
Kari
system
March 10, 2011, 9:54pm
9
Yes, in arduino i can only choose from COM4 to 17...
GaryP
March 10, 2011, 9:59pm
10
maxidvd:
Can you take a screenshot of that part of the menu? Sounds very strange.
Kari
GaryP
March 10, 2011, 10:31pm
12
You IDE has gone grazy!
Seems like it show everything else but actual co port. Does you device manager show COM1 or COM2.
Kari
system
March 10, 2011, 10:56pm
13
It seems that print screen isn't working anymore...
just one minute...
EDIT:
GaryP
March 11, 2011, 6:02am
14
Seems to my that your correct port is COM10, have you tried that?
Cheers,
Kari
GaryP
March 11, 2011, 7:16am
16
maxidvd:
yes of course...
Yes of course... "Yes, you have tried" or "Yes of course, I should have tried that and it works"?
Cheers,
Kari
system
March 11, 2011, 1:10pm
17
I tried and it didn't work...
GaryP
March 11, 2011, 2:19pm
18
Ok. Then I must apologise, I cannot help more.
Does it work with another computer? If the same problem exists, then your Arduino is probably broken. Oh, I read the first post again, problem lies in your Windows. Drivers are ok?
Kari
system
March 11, 2011, 4:33pm
19
yes it works an my asus netbook as i said before
yes, the seems to be ok
