Writing to text file
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
// skipped/blocked the first Line OPEN
      bool firstLine = true;
while (myFile.available()) {
  int c = myFile.read();
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
    Serial.write(c);
how can I write the "c" in my other text file which is temp.txt
Open myOtherFile = SD.open("temp.txt") and use myOtherFile.write(c);
Can I open two File?
You can: open as many files as your RAM allows.
You can't: open the same file in multiple instances.
when I do this... no output... even the Serial.write(c)
  myFile = SD.open("temp.txt", FILE_WRITE);
  if (myFile) {
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
   Serial.write(c);
   myFile.write(c);
 myFile.close();
but if I do this, i got tthis
 // myFile = SD.open("temp.txt", FILE_WRITE);
 tempFile = SD.open("temp.txt", FILE_WRITE);
  if (myFile) {
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
    Serial.write(c);
    tempFile.write(c);
myFile.close();
tempFile.close();
output:
22222
33333
44444
55555
22222
33333
44444
55555
example expected output:
22222
33333
44444
55555
It is quite hard to say what is wrong.
Bad formatting in the code? (P.S. try using the auto format function in the IDE)
Mismatched braces (there are more open than closed)? (P.S. please post the complete program, or at least the complete function in question)
SixtoD:
output:
22222
33333
44444
55555
22222
33333
44444
55555
22222
33333
44444
55555
I bet it's because temp.txt already existed in the second test run. Try opening it this way:
tempFile = SD.open("temp.txt", O_WRITE | O_CREATE | O_TRUNC);
hello sir @Lucario448
when i use this code:
Lucario448:
im getting this error msg: 'O_CREATE' was not declared in this scope
what library should i use to use O_CREATE?
here's my whole code
#include <SPI.h>
#include <SD.h>
File myFile;
File tempFile;
char cr;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  // re-open the file for reading:
 //tempFile = SD.open("temp.txt", FILE_WRITE);
  if (myFile) {
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
  //Serial.write(c);
  tempFile.write(c);
myFile.close();
tempFile.close();
// skipped/blocked the first Line CLOSED
  else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // nothing happens after setup
try O_CREAT?
Yeah thanks!
I didn't remember how that definition is named; obviously if I recalled it wrong, a compilation error happens.
Now I'm pretty sure it's O_CREAT, because how the other options are named: O_[the first five characters of the word in uppercase]
thank you very much Sirs...
big help for me...
