Okay, so now I'm trying it without the tft screen with 3 led's and this code:
Source Code
Now let’s see the Arduino sketch. I will use the pins number 7, 6 and 5 and I will name them redPin, greenPin and bluePin. In the setup section we need to define them as outputs. At the bottom of the sketch we have this custom made function named setColor() which takes 3 different arguments redValue, greenValue and blueValue. These arguments represents the brightness of the LEDs or the duty cycle of the PWM signal which is created using the analogWrite() function. These values can vary from 0 to 255 which represents 100 % duty cycle of the PWM signal or maximum LED brightness.
int redPin= 7;
int greenPin = 6;
int bluePin = 5;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
setColor(255, 0, 0); // Red Color
setColor(0, 255, 0); // Green Color
setColor(0, 0, 255); // Blue Color
setColor(255, 255, 255); // White Color
setColor(170, 0, 255); // Purple Color
void setColor(int redValue, int greenValue, int blueValue) {
analogWrite(redPin, redValue);
analogWrite(greenPin, greenValue);
analogWrite(bluePin, blueValue);
I keep getting this message though: A function definition is not allowed here before '{' token. It shows up on the loop option, after the end of the code. Any suggestions?
