YetAnotherArduinoFan:
I have waited, to see what happens, even over night. The booting does not get beyond eth1:link up.
That part is normal - that is indeed the last boot message. About 10 or 20 seconds after that, the white light should go on, at least for the arduino.cc version of the board (which is what I have - you say yours is from arduino.cc, but your Yun is running Linino, which is typical for arduino.org boards.)
I captured the output of my boot process and compared it to yours. I see some differences, but they do not appear to be significant, they are mostly related to being different Linino vs Arduino builds (things like dates, names, etc.) There are some slight differences in the WiFi message formats around 38 to 40 seconds into the log. I have a couple more messages about loading USB device drivers that I have installed. The last line for both our boot sequences is that Ethernet is up, your's is 10 MB Half duplex, mine is 100 MB Full duplex (a function of the type of port that is on the other end of the cable.)
Assuming you are using the YunSerialTerminal sketch and the Arduino Serial Monitor, if you are at the point where that last message has come out, you should be able to hit "Send" on the Serial Monitor, and you should see the command line banner. Type ifconfig in the Serial Monitor command box, and hit send again. You should see the current network configuration. Make note of the "inet addr" for eth1.
Then, type pretty-wifi-info.lua into the Serial Monitor command box, and hit send again. This will display the WiFi status, which is the exact same output generated by the WiFi Status Example sketch. This will let you know the WiFi status. Post it if you don't fully understand it.
Even if WiFi is not connecting for you, since you apparently have the Ethernet port connected, you should be able to log in that way. Take the "inet addr" noted above, and type that into a web browser address bar. You should be able to access the Yun that way and log into the configuration pages. That will then give you chance to set up the WiFi networking.
If you run into trouble, you can manually run the reset scripts as long as you are able to enter commands in the Serial Monitor through the YunSerialTerminal sketch:
- wifi-reset-and-reboot will do the same thing as the short (5 second) reset press
- reset-to-factory-anyway && reboot will do the same thing as the long (30 second) reset press
