Hello guys I am having this arduino uno project on thermal sensors sending temperature signals to webpage via ethernet cable / setup.
Problem is when I open the webpage using the IP address, it gives me a negative value of -196.60.
Thermal sensor works and I have tested it using another set of codes, it gives values on serial monitor whenever there is a temperature change, I combined both set of codes I got and it still doesnt display the actual value on the webpage.
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 12
float tempC, tempF;
float sumTempC, sumTempF;
float avgTempC, avgTempF;
float minTempF, maxTempF;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//Permanent Board
DeviceAddress thermoOne = {
0x28, 0x20, 0x05, 0xB4, 0x04, 0x00, 0x00, 0x7B};
DeviceAddress thermoTwo = {
0x28, 0xBC, 0xBA, 0xB4, 0x04, 0x00, 0x00, 0x97};
byte mac[] = {
0x48, 0xC2, 0xA1, 0xF3, 0x8D, 0xB7};
byte ip[] = {
192,168,137,177};
EthernetServer server = EthernetServer(80);
minTempF = -1.0;
maxTempF = 500.0;
Ethernet.begin(mac, ip);
server.begin();
sensors.begin();
sensors.setResolution(thermoOne, TEMPERATURE_PRECISION);
sensors.setResolution(thermoTwo, TEMPERATURE_PRECISION);
void getTemperature(DeviceAddress deviceAddress)
tempC = sensors.getTempC(deviceAddress);
tempF = DallasTemperature::toFahrenheit(tempC);
sensors.requestTemperatures();
sumTempC = sumTempF = 0.0;
getTemperature(thermoOne);
sumTempC += tempC;
sumTempF += tempF;
getTemperature(thermoTwo);
sumTempC += sumTempC;
sumTempF += sumTempF;
avgTempC = sumTempC / 2.0;
avgTempF = sumTempF / 2.0;
if(minTempF < 0.0)
minTempF = avgTempF;
else if(minTempF > avgTempF)
if(maxTempF > 499.0)
maxTempF = avgTempF;
else if(maxTempF < avgTempF)
if(client)
boolean BlankLine = true;
while(client.connected())
if(client.available())
char c = client.read();
if(c == '\n' && BlankLine)
client.println("Content-Type: text/html\n");
client.println("<META HTTP-EQUIV=""refresh"" CONTENT=""5"">\n");
client.println("Arduino Web Server");
client.println("<body style="background-color:#5EA084">\n");
client.println("
Arduino Web Server
");client.println("
Current Temperature
");client.println(avgTempF);
client.println("°F");
client.println("
client.println("
Minimum Temperature
");client.println(minTempF);
client.println("
client.println("
Maximum Temperature
");client.println(maxTempF);
client.println("\n");
if(c == '\n')
BlankLine = true;
else if(c != '\r')
BlankLine = false;
delay(10);
client.stop();
