i am trying to send a char array using arduino uno board andNRF24L01 modules
Here is the code for both transmitter and receiver
//~ 1 - GND
//~ 2 - VCC 3.3V !!! NOT 5V
//~ 3 - CE to Arduino pin 9
//~ 4 - CSN to Arduino pin 10
//~ 5 - SCK to Arduino pin 13
//~ 6 - MOSI to Arduino pin 11
//~ 7 - MISO to Arduino pin 12
//~ 8 - UNUSED
#include <SPI.h>
//~ #include <TMRh20nRF24L01.h>
//~ #include <TMRh20RF24.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
// These are the IDs of each of the slaves
const uint64_t slaveID[2] = {0xE8E8F0F0E1LL, 0xE8E8F0F0E2LL} ;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[64]="e7665072be018b6b58ea9e40cf38553d6dc293cda4c9d94cda6e91ca61b3a073";
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
int txVal = 0;
float ackMessg[2]={1,2};
byte ackMessgLen = 4; // NB this 4 is the number of bytes in the 2 ints that will be recieved
Serial.println("Track Control Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.enableAckPayload();
radio.setRetries(3,5); // delay, count
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
radio.openWritingPipe(slaveID[0]); // calls the first slave
// there could be a FOR loop to call several slaves in turn
bool rslt;
rslt = radio.write( dataToSend, sizeof(dataToSend) );
Serial.print("\nRSLT (1 = success) ");
Serial.println(rslt);
Serial.print("Data Sent ");
Serial.print(dataToSend[0]);
Serial.print(" ");
Serial.println(dataToSend[1]);
if ( radio.isAckPayloadAvailable() ) {
radio.read(ackMessg,ackMessgLen);
Serial.print("Acknowledge received: ");
Serial.print(ackMessg[0]);
Serial.print(" ");
Serial.println(ackMessg[1]);
prevMillis = millis();
//~ 1 - GND
//~ 8 - UNUSED
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const uint64_t deviceID = 0xE8E8F0F0E1LL; // Define the ID for this slave
int valChange = 1;
char dataReceived[64];
int ackData[2] = {12,23};
Serial.println("Hand Controller Starting");
radio.begin();
radio.openReadingPipe(1,deviceID);
radio.writeAckPayload(1, ackData, sizeof(ackData));
radio.startListening();
if ( radio.available() ) {
radio.read( dataReceived, sizeof(dataReceived) );
for (int x = 0; x <64; x++) {
//if (dataReceived[x] < 16) {
// Serial.write('0');
Serial.print(dataReceived[x]);}
ackData[0] += valChange; // this just increments so you can see that new data is being sent
the receiver receives half of the array only
here is a copy from the output that i get on my receiver
Hand Controller Starting e7665072be018b6b58ea9e40cf38553d
Not that Iknow of. I have never had the need to exceed the 32 byte limit. In the link that I posted it is suggested that you split up the data into as many packets as necessary and send, along with the first packet, the number of packets for the receiver to expect.
groundFungus:
yes i have read the suggestion in the post but i am asking if there is a tested way to do that
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
hello Robin
thank u very much for ur reply
the problem that i am facing is the payload size as my char array is more 32 ,so is there a way or an example that explains that?
that should not be rocket science with pointers esp. as your array is 64 = 2 x 32
char dataToSend[] = "e7665072be018b6b58ea9e40cf38553d6dc293cda4c9d94cda6e91ca61b3a073";
char* ptr1 = dataToSend;
char* ptr2 = dataToSend + 32;
// then send ptr1 with 32 bytes and then ptr2 with 32 bytes as well (or sizeof(dataToSend)-32
// You might want to think about sending the trailing null or not
and you need possibly some info to say if this is the first part or second part of the message, so may be need to cut in 3 parts as it won't fit
Yea, I'd define a packet struct and send the data in 3 packets with payloads sizes of 21, 21, and 22 bytes. The first byte of the struct would indicate which chunk it is (0, 1, 2). This would also form a sequence number to tell you if you ever drop a packet. In that case, scrap the entire message and wait for the start of the next 3-packet group.
I think the NRF24L01 frame includes a checksum and the received frame is dropped if it doesn't match. So, you should only receive valid frames. Hence, you don't need to include a checksum in your packet.
gfvalvo:
struct packet {
uint8_t idNumber;
char payload[22];
interesting method ,but i have not used struct before with nRF
how can i do that?
how to do that using pointers ?,i am not familiar with pointers at all
