Hi guys
i'm trying to make a telemetry for apm using two nRF24L01P and two arduino mega2560(because of tree serial inputs). i made two sketches one for receiver and the other one for transmitter. the telemetry port of APM has RX and TX pins, at first i connect the RX pin of APM to TX1 pin(pin 18) on arduino mega2560, TX pin of APM to RX1 pin(pin 17) on arduino then i wrote some easy sketch like below and it works mission planner connected to APM using arduino without any problem.
// initialize both serial ports:
Serial1.begin(115200);
// read from APM , send it to arduino serial:
while (Serial1.available()) {
uint8_t inByte = Serial1.read(); // it works with char and byte also
Serial.write(inByte);
// read from arduino serial, send it to APM:
while (Serial.available()) {
uint8_t inByte1 = Serial.read(); // it works with char and byte also
Serial1.write(inByte1);
it is working well with mega2560 i try this with arduino nano (but different code) it works fine but slow cuase of that i had to use mega2560 and thats fine by me.
so with this idea i'm trying to use nRF24L01p to communicate with each other , but it seems to have a problem sometimes it connects and sends data BUT it seems that there is a problem in communication because APM sends data again and again like there is not ack or some data losts.
Transmitter code:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
const int CE_pin = 7;
const int CSN_pin = 8;
RF24 radio(CE_pin, CSN_pin);
const byte rxAddr[][6] = {"Miki1" , "Miki2" };
const int led_pin = 46;
const int led_pin1 = 47;
const int led_pin2 = 13;
bool radio_state = 1;
SPI.begin();
pinMode(led_pin,OUTPUT);
pinMode(led_pin1,OUTPUT);
pinMode(led_pin2,OUTPUT);
digitalWrite(led_pin,LOW);
digitalWrite(led_pin1,LOW);
digitalWrite(led_pin2,LOW);
radio.begin();
//radio.enableDynamicPayloads();
//radio.enableDynamicAck();
//radio.enableAckPayload();
//radio.setPayloadSize(128);
radio.setChannel(123);
radio.setDataRate(RF24_2MBPS);
radio.setPALevel(RF24_PA_MAX);
//radio.openReadingPipe(1, rxAddr[0]);
//radio.openWritingPipe(rxAddr[1]);
//radio.setRetries(0, 15);
//radio.startListening();
radio.stopListening();
if(!radio_state){
while (radio.available() ){
digitalWrite(led_pin,HIGH);
byte inByte1;
radio.read(&inByte1,sizeof(inByte1));
Serial1.write(inByte1);}
delay(5);
radio_state = !radio_state;}
if(radio_state){
while (Serial1.available() ) {
digitalWrite(led_pin1,HIGH);
byte inByte= Serial1.read();
radio.write(&inByte,sizeof(inByte));}
Receiver Code :
#include <SPI.h>
#include <RF24.h>
//const int led_pin = 2;
//const int led_pin1 = 3;
bool radio_state = 0;
SPI.begin();
radio.begin();
radio.setDataRate(RF24_250KBPS);
//radio.openReadingPipe(1, rxAddr[1]);
//radio.openWritingPipe(rxAddr[0]);
if(!radio_state){
radio.openReadingPipe(0, rxAddr[1]);
byte inByte1;
Serial.write(inByte1);}
delay(5);
if(radio_state){
byte inByte = Serial.read();
radio_state = !radio_state; }
Dont mind the led pins i put them to check where the data flows or not.
if anyone did this please help me or point me to the problem in my code, i will appreciate it.
thanks
