daleldalel:
Just in case someone was looking for arduino code to decode Livolo remotes.#define SIGNAL_IN 0 // INTERRUPT 0 = DIGITAL PIN 2 - use the interrupt number in attachInterrupt
volatile byte impulse = 0; // kolejny puls
volatile int bufor[53];
volatile boolean header = false;
volatile unsigned long StartPeriod = 0; // set in the interrupt
volatile boolean stop_ints = false;
attachInterrupt(SIGNAL_IN, calcInput, CHANGE);
if (stop_ints) //data in buffer
unsigned long binary = 1;
//byte i = 0;
for (byte j = 0; j < 46; j++)
//Serial.print(binary);
if ((bufor[j] > 220) &&
(bufor[j] < 400))
binary <<= 1;
//binary |= 1;
//i++;
bitSet(binary,0);
else if ((bufor[j] > 90) &&
(bufor[j] < 220) && (bufor[j + 1] > 90) &&
(bufor[j + 1] < 220)) {
binary <<= 1;
j++;
(bufor[j] < 220) && (bufor[j + 1] > 220) &&
(bufor[j + 1] < 400)) {
binary <<= 1;
bitSet(binary,0);
//i += 2;
j++;
else break;
//Serial.println(bitRead(binary,4));
if (bitRead(binary,23))
bitClear(binary,23);
Serial.print("remoteID:");
Serial.print((binary / 128) & 65535);
Serial.print(" - ");
Serial.print("key code:");
Serial.println(binary & 127);
else {
Serial.println("wrong code ");
Serial.println(binary, BIN);
delay (1000);
header = false;
impulse = 0;
stop_ints = false;
// interrupt below...
void calcInput()
// get the time using micros
unsigned int duration = (int)(micros() - StartPeriod); // save pulse length to bufor
StartPeriod = micros(); //begin next impulse
//Serial.println(StartPeriod);
if (stop_ints) return;
if ((duration < 90) || (duration > 600)) goto reset; //impulse not right
bufor[impulse++] = duration;
if (duration < 415) return;
if (!header)
header = true;
impulse = 0;
return;
if ((impulse < 23) || (impulse > 52)) goto reset; //too long or too short info
stop_ints = true;
return;
reset:
header = false;
impulse = 0;
return;
Thanks to platenspeler and spch Improved code
Doesn't work for arduino due!
