Thanks for your help David it works.
the threshold value is ok now with 200
Best regards
Frederico
Best regards
Frederico
Fantastic!!! Thats just the solution for what I've been trying to do in the last days! It worked well, but slower then when loading bmp with showBMP. Now I'm trying to build a similar sketch for bmp files, but no success yet. Next step will be for jpeg files.
Many Thanks David!!!
Hi to all,
I got the next SPI TFT ILI9341
I tried running a examples from Adafruit_ILI9341 library, and I get a white screen.
Is there a recommendation for another library? And what connections?
Thanks a lot.
The back side is this.
The MCUFRIEND_kbv library is for Mcufriend Uno shields.
It does NOT support the SPI TFT ILI9341. But there are plenty of libraries that do. e.g. Adafruit_ILI9341, TFT_ILI9341, ILI9341_due, ILI9341_PDQ, ...
Note that your screen requires 3.3V logic. e.g. Zero, Due, Teensy3.x, ...
If you want to use a 5V Uno or Mega, you MUST use level shifters.
David.
First of all thank you,
As I wrote, I tried the sample from the library Adafruit_ILI9341 and I get a white screen.
I'll try the rest you recommend.
Thanks.
Adafruit examples deliberately omit the RST argument in the constructor.
Presumably to make their screens work and your screen fail.
Add the optional RST argument for your Red screen. Google "ILI9431 SPI Adafruit". Ask on relevant threads.
David.
Thanks for the offer, but I did not really understand what to do with RST.
Can you please explain?
Thanks.
Hello David, I modified the example "no_showBMP_Uno" with the purpose of simplifying it to show only one BMP (16 or 24bit) and build a specialized function after. It worked well but I think it could simplify more.
Could you please review the attached skecth for me?
Thanks a lot my friend!!!!!
TESTE_show_1_BMP_not_Uno-MINHA.ino (10.1 KB)
Some of your edits are unwise. e.g. not testing for TFT ID or valid BMP ID.
I suggest that you always press ctl-T to format your code nicely. It makes all the difference to readability.
Personally, I would delete all the extraneous lines. Even with the ctl-T formatted sketch, it is still clearer without the unused lines.
Did you try my example?
David.
Yes, I tried your example and replied this on #1979:
"Fantastic!!! Thats just the solution for what I've been trying to do in the last days! It worked well, but slower then when loading bmp with showBMP. Now I'm trying to build a similar sketch for bmp files, but no success yet. Next step will be for jpeg files.
Many Thanks David!!!"
I learn more and more each time I read your posts.
Here's the last and cleanest version of the adapted "show_BMP" that I could build:
// MCUFRIEND UNO shields have microSD on pins 10, 11, 12, 13
// The official <SD.h> library only works on the hardware SPI pins
// e.g. 11, 12, 13 on a Uno
// e.g. 50, 51, 52 on a Mega2560
// e.g. 74, 75, 76 on a Due
// if you are not using a UNO, you must use Software SPI:
// install v1.0.1 of the <SdFat.h> library with the Arduino Library Manager.
// edit the src/SdFatConfig.h file to #define ENABLE_SOFTWARE_SPI_CLASS 1
// copy all your BMP files to the root directory on the microSD with your PC
// (or another directory)
// * Adapted from "Show_BMP_not_Uno.ino" (One of the examples from "MCUFRIEND_kbv Library
// for Uno 2.4, 2.8, 3.5, 3.6, 3.95 inch mcufriend Shields" by PRENTICE, DAVID).
// https://github.com/prenticedavid/MCUFRIEND_kbv
// PURPOSE: A simpler possible function to Load/Show only one BMP at a time from SD card.
// RESTRICTED CONDITIONS: - Image Files: 16 or 24bitBMP (w<=320, h<=240).
// - Uno tft Shield: mcufriend 2.8" Blue (HX8347D; ID=0x4747).
// - Shield plugged on Mega 2560 R3.
// Still under construction.
// VERY GRATEFUL TO DAVID FOR THE VALUABLE LESSONS AND KINDLY "PATIENCE" WITH A NEWBIE.
#include <SPI.h> // f.k. for Arduino-1.5.2
#include <SdFat.h> // Use the SdFat library
#include <Adafruit_GFX.h> // Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
SdFatSoftSpi<12, 11, 13> SD; //Bit-Bang on the Shield pins
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL 20
{ tft.begin(0x4747);
SD.begin(10);
tft.setRotation(3);
void loop() { //FOR TESTS
char *imagefile = "/test/MOTO_CORRIDA_16bit.bmp"; //var imagefile MUST BE ASSIGNED ON THE MAIN SKECTH
tft.fillScreen(0);
showBMP(imagefile, 0, 0);
imagefile = "tiger_24bit.bmp"; //var imagefile MUST BE ASSIGNED ON THE MAIN SKECTH
tft.fillScreen(0);
uint16_t read16(File& f) {
uint16_t result; // read little-endian
f.read(&result, sizeof(result));
return result;
uint32_t read32(File& f) {
uint32_t result;
return result;
uint8_t showBMP(char *imagefile, int x, int y)
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24, 16, 8, 4, 1)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3 * BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
uint16_t lcdbuffer[1 + BUFFPIXEL];
uint8_t bitmask, bitshift;
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col, lcdbufsiz = 1 + BUFFPIXEL, buffidx;
uint32_t pos; // seek position
boolean is565 = false; //
uint8_t ret;
bmpFile = SD.open(imagefile); // Parse BMP header
(void) read16(bmpFile);
(void) read32(bmpFile); // Read & ignore file size
(void) read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
(void) read32(bmpFile); // Read & ignore DIB header size
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
(void)read16(bmpFile);
bmpDepth = read16(bmpFile); // bits per pixel
pos = read32(bmpFile); // format
bool first = true;
is565 = (pos == 3); // ?already in 16-bit format
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
if (bmpHeight < 0) { // If negative, image is in top-down order.
bmpHeight = -bmpHeight;
flip = false;
w = bmpWidth;
h = bmpHeight;
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
for (row = 0; row < h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
uint8_t r, g, b, *sdptr;
int lcdidx, lcdleft;
if (flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if (bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col = 0; col < w; ) { //pixels in row
lcdleft = w - col;
if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) { // buffer at a time
uint16_t color;
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
r = 0;
switch (bmpDepth) { // Convert pixel from BMP to TFT format
case 24:
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
color = tft.color565(r, g, b);
break;
case 16:
if (is565)
color = (r << 8) | (b);
color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
break;
lcdbuffer[lcdidx] = color;
tft.pushColors(lcdbuffer, lcdidx, first);
first = false;
col += lcdidx;
} // end cols
} // end rows
tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1); //restore full screen
bmpFile.close();
How to load Bitmap with library utftglue?
WHY?
What kind of Bitmap?
I kludge this UTFT method in UTFTGLUE:
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int scale=1);
but I make no attempt to draw a bitmap at an angle i.e. this UTFT method:
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int deg, int rox, int roy);
I provide example showBMP sketches for rendering BMP files from SD card.
The Adafruit_GFX class has several methods:
drawBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
int16_t w, int16_t h, uint16_t color),
int16_t w, int16_t h, uint16_t color, uint16_t bg),
drawBitmap(int16_t x, int16_t y, uint8_t *bitmap,
drawXBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
drawGrayscaleBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
int16_t w, int16_t h),
drawGrayscaleBitmap(int16_t x, int16_t y, uint8_t *bitmap,
const uint8_t bitmap[], const uint8_t mask[],
uint8_t *bitmap, uint8_t *mask, int16_t w, int16_t h),
drawRGBBitmap(int16_t x, int16_t y, const uint16_t bitmap[],
drawRGBBitmap(int16_t x, int16_t y, uint16_t *bitmap,
const uint16_t bitmap[], const uint8_t mask[],
uint16_t *bitmap, uint8_t *mask, int16_t w, int16_t h),
The GFX drawBitmap() methods are monochrome. The GFX methods end up by drawing one pixel at a time. It is faster to use TFT hardware.
David.
Thanks!
I'd like to to draw a bitmap from sd card.
showBMP_kbv_as7 works fine, but this sketch work on MCUFRIEND_kbv tft - not utftglue.
Why do you want UTFTGLUE?
UTFTGLUE only sends UTFT methods to the underlying MCUFRIEND_kbv object.
What do you want to do with UTFT style methods that can not be done with Adafruit_GFX methods?
In fact you will find that a UTFTGLUE object is able to perform both UTFT and GFX methods.
I strongly advise you to stick to GFX. Only use UTFTGLUE for a legacy UTFT program. Never try to mix both styles because it gets confusing.
David.
So I shoud use MCUFRIEND_kbv? How to, for example change text font?
Read the Adafruit_GFX docs for setFont().
There are FreeFonts versions of the UTFT DefaultFonts if you happen to enjoy those particular fonts.
If there is some unusual font that you want to use, just ask. Make sure that you provide a link to this special font. I will possibly convert it to FreeFont for you.
David.
Thanks David!
Is it possible to change brightness?
Thanks for all your hard work David. If it wasn't for your MCUFriend library I would have never gotten my display to do anything. I'm fairly new to programming and It’s probably obvious to most, but after searching for several weeks I'm still trying to figure out the significance of the # that precedes many of the keyword2's in the Mcufriend_kbv keywords.txt file.
My sketch begins with:
MCUFRIEND_kbv tft;
and the examples show that one preceeds the keywords without an # with tft. but how does one use the keywords with an #. In particular I’ve been trying to make use of printNumF, but all I ever get is errors, such as 'class MCUFRIEND_kbv' has no member named 'printNumF'. (I’m guesing some other library is also needed.)
