Hi
I'm learning about the Arduino using the Most Complete Starter Kit and have been playing with the Heltec ESP32 Wifi kit also.
Currently, with the Arduino, i am trying to use an IR LED to control my Panasonic tele. So i used the IR sensor and read a load of codes from my existing remote and then used the ITSendDemo sketch as a basis to start controlling the tele. They were all 8 bytes in length apart from 1 which I assumed had a leading 0 dropped by the print command.
In a nutshell, none of the codes i recorded seem to work when I resend them except the On/Off code, but there's even something strange going on there.
when I read the ON/Off code I mostly got 0xf61e2a57 but occasionally (~1 in 10) got 0x100BCBD - Only the latter works when I resend it.
none of the other codes work eg Button No 1 0xf7283c77. In fact the LED on the tele doesn't even flash as it does when the proper controller is pressed.
As per the example, I'm using 0x4004 as the address for everything in the irsend.sendPanasonic(address, command) lines. I don't actually understand what the address is!
Any help would be appreciated. Thanks
Graham
