NTE262 transistor which is supposed to be similar to the tip120.
I want to program the arduino to do to move the dc motor for example: 2 rotations clockwise, then stop, go 2 rotations counterclockwise, stop, 1/4 rotation clockwise, stop, 1/4 rotation counterclockwise
If that is confusing I have a video that will show exactly what I mean dancing bot - YouTube bigger circle in the bottom is connected to the motor through gears that makes the movement.
With that motor? Forget it. It isn't a servo or stepper.
You'll have to make your own servo. This will involve adding a rotation sensor, either a pot or a rotary encoder, and PID control. I would suggest a rotary encoder for your application.
Does the motor have some sort of brake mechanism? Motors, especially large motors, have a fair amount of inertia. Once you get it to turn two revolutions, you'll need a way to stop it. You can apply a short pulse of reverse polarity voltage, but that might be inconsistent. Hopefully the large motor has a brake.
I was thinking of using a servo, but they are not strong enough for the right price to handle the heavy equipment being held up by the motor, unless you can recommend one. thank you
MaJiG:
What I am going to do with the motor is actually add a bunch of gears to slow it down drastically and increase the torque. When I test the small motor the toy has with 3 AAA batteries and the bigger motor with the 12V battery, they both stop and go at the same speed.
futurenbain8:
What sort of force, travel and speed do you require?
