Hi guys, its my first post and i am a rookie in Arduino programming. I need help in incorporating 2 things into 1 program. First of all im running 2 peristaltic pump on L298N with my UNO. i made the pumps run a certain way and also try to put in a push button when its no running anymore but i cant get them both to work. It is either the PumpRun or the push button. How to i make it work together? firstly, i would like the PumpRun to run its course then have the ability to use the press button to turn on the pump when i need it to outside of the PumpRun. The sketch below allow me to run PumpRun but i cant seem to make the button work.
// Motor A
int enA = 9;
int in1 = 8;
int in2 = 7;
// Motor B
int enB = 3;
int in3 = 5;
int in4 = 4;
int button = 2;
int buttonState = 0;
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(button, INPUT);
void PumpRun()
// Turn on motor A 1200ML
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
analogWrite(enA, 120);
// Turn on motor B 1400ML
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
analogWrite(enB, 170);
// Set Duration of Motor Run
delay(360000);
// Now turn off motors
digitalWrite(in1, LOW);
digitalWrite(in3, LOW);
delay(360000);
PumpRun();
// read the state of the pushbutton value:
buttonState = digitalRead(button);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH)
// turn Pump on:
} else
// turn Pump off:
TIA.
