I am new to Arduino products but would like to use them for a project i have.
I am into model railways and would like to create a bluetooth control for one of my trains. Please could you give me some guidance on what to and the feasibility of this project and what to buy. Details are below.
The rails a powered to 12V DC. I plan to use this to power the train, module and controller.
Train has one motor. This needs to be controlled via bluetooth.
I would like to have the option to control the train headlights which are LED's. Is this possible?
I would like to control the train from my Android phone.
The only problem with track power is that the Arduino will reset if there is even a very short disconnection.
What is the maximum voltage on the track power? The voltage range for a Nano is 7-12v and many model railways work with 14v or 16v. If running from track power it might be wise to use a 7805 voltage regulator to provide a 5v supply for the Nano's 5v pin.
Have you space for a couple of AA batteries - they would run an Arduino for a long time.
nphadke:
The scale I am working on is HO so have abt 100x 28x26 mm space. I don't think it will fit two AA batteries, but may accommodate two AAAs.
That seems a huge space.
I am building a Battery Powered R/C 00 tank loco and I have about 20x30x16mm for the electronics and about 9x30x16 for the battery. And I have built BPR/C into an N Gauge tank loco.
This is a picture of an early version of my receiver without the motor driver
I am using nRF24L01+ transceivers rather than Bluetooth
Another battery option for your model is a 1s LiPo. If it is only powering the Arduino an 80mAh cell would last a long time. The cells I have are 9mm diam x about 18mm long. (I got that down to 16mm with a bit of "repackaging"). Just be careful when charging LiPos and never allow them to short-circuit.
