Topic: Change frequencies by arduino (Read 1 time) previous topic - next topic
allanhurst
The video showa a breakout board purchased from ebay  - so you don't need to mount the chip .
It provides 0..31.5dB attenuation in 64 0.5dB steps  .
It requires a 3-v logic interface, so you'd either need a 3.3v arduino - eg a due , or a simple 5-3.3v conversion interface to use with a 5v arduino. This can be done with a few resistors.
Note : this device does not alter frequencies.
Allan
avibd
The package is a QFN package (look it up, that's what google is for!).  This is extremely small, cannot
be soldered by hand (except by some crazily skilled folks!), requires a PCB to be made with solder-mask,
then solder paste applied with a stencil, then the device accurately placed on the paste and the board
heated in an oven or with a hot-air rework station.
In otherwords you will require it on a break-out board, unless you have good surface-mount soldering
skills.
But its a 3V only chip, so if you are using a 5V Arduino you'd be better off with a 5V compatible chip
so you don't need level-shifters.  Alternatively use a 3.3V Arduino to talk to it.
I buy breakout board like this but PE4312C instead of pe4302
https://www.amazon.com/Qianson-DC-4GHz-Attenuator-Linearity-0-5dB-31-5dB/dp/B01ILU52OO
datasheet pe4312c:
http://html.alldatasheet.com/html-pdf/929247/PSEMI/PE4312C-Z/152/1/PE4312C-Z.html
avibd
Allan
I search for breakout board with this component
allanhurst
The pe4312 seems to be a slightly higher performance version  of the PE4302.
It's range is 1MHz .. 4GHz.
It requires a 1.8 to 3.6v logic drive.
It does NOT alter the frequency, only it's amplitude.
So how else could we help you?
Allan
avibd
Allan
I have one more question
in pe4302 breakout board written that the range is: "DC-4GHz"
what does "DC" mean?
allanhurst
DC = direct curent ie a frequency of 0Hz.
 Their claim is innaccurate, as I pointed out, as the chip only claims to go down to 1MHz
Allan.
MarkT
I am worried about your lack of knowledge of the _most_ _most_ basic terminology - please
explain exactly what you are trying to do, ie what end result you want to achieve, I have
a worry that you are completely confused about frequency, amplitude, signal processing in
general.   Don't say _how_ you think the result should be achieved, say _what_ result you want.
avibd
I thought so but I was not sure
Get basic knowledge of software electronics a little less
And unfortunately for the project I'm doing I'm not sure how much I can tell for several reasons
allanhurst
In which case there's a limit to how much we can help you.
Learn a lot of electronics, or ask someone knowledgable you can trust.
Allan
