There is no steps
Do you understand what "Can you recheck your steps" mean? Please do say when you don't understand something I have told you to do, I have told you this before, my rule is third time and I walk away!
OK I have been doing some checking and somewhere along the line you changed
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
into
Keypad kpd = Keypad( makeKeymap(48), rowPins, colPins, ROWS, COLS );
The variable keys is NOT a number, it is a pointer to an array.
However the big big problem now is that the Keypad library doesn't seem to return a released state, so while you can send MIDI note on, you can't trigger MIDI note off.
Try this code. I expect that for very short key presses you might get a note stuck on, and for longer presses you will just here a short note, but I want to test that the notes are in the right order.
#include <Keypad.h>
const byte ROWS = 6; //six rows
const byte COLS = 9; //nine columns
char keys[COLS][ROWS] = {
{36, 45, 54, 63, 72, 81},
{37, 46, 55, 64, 73, 82},
{38, 47, 56, 65, 74, 83},
{39, 48, 57, 66, 75, 84},
{40, 49, 58, 67, 76, 85},
{41, 50, 59, 68, 77, 86},
{42, 51, 60, 69, 78, 87},
{43, 52, 61, 70, 79, 88},
{44}
byte rowPins[ROWS] = {26, 28, 30, 32, 34, 36}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {A0, A1, A2, A3, A4, A5, A6, A7, A8}; //connect to the column pinouts of th
int pressed = 32;
byte chanel = 0; // MIDI channel to use
Serial.begin(115200); // set this the same as Hairless
// Fills kpd.key[49] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
pressed = (kpd.key[i].kchar);
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case HOLD:
sendMIDI(chanel | 0x80, pressed, 0);
break;
case PRESSED:
sendMIDI(chanel | 0x90, pressed, 80);
break;
case RELEASED: // this never seems to trigger
break;
} // End loop
void sendMIDI(byte type, byte note, byte velocity){
Serial.write(type);
Serial.write(note);
Serial.write(velocity);
