Making a calculator using an Arduino
the Serial.print() to see what data I have
I think that is ok but sometimes we use flushing and Packets atleast at the end of the elements we are sending so as to make them land complete in the programme but nevermind as you are saying that the keypad isn't that much conductive.
And I know, a lost of breadboarding.
A a lots of BreadBoarding atleast its easier than the Solder breadboarding.
Updated :
I got the keyboard working better by using 74HC14. But a few "double entry" and a few "not reading right". In that case, I will use the LM339 to take care of the keypad "bad contact". Just a lots of breadboarding.
I just finish coding the calculator program. So far, The "Add" section is not working right. I may need some help. The rest is working fine. The "Clear" section is working fine. I will double check the "keynumber" section. Look it is working fine, but I will double check it.
I may re-code the "add" section. Instead of extracting the thousands, hundrens, tens, etc, and use a long variable, I will try the method use when we where in Grade 3. How to add a number.
Any help from you guys will be nice.
Here the Add section:
// Check for the "Add / Equal" button
    if ( ( keynumber == 0x0B ) && ( over_flow == 0) )
      the_number= 0;
      for (int i=0;i<8;i++)
        temp_number = long(digit_number[i]) * power_of_ten[i];
        the_number = the_number + temp_number;
      add_number = add_number + the_number;
      if (add_number <= 99999999)
        for (int i=7;i>=0;i--)
          digit_number[i] = byte(add_number / power_of_ten[i]);
          add_number = add_number - (long(digit_number[i]) * power_of_ten[i]);
          display_data[i] = word ( ( i + 1) , digit_number[i] );
        for (int i=7;i>0;i++)
          if ( digit_number[i] == 0 )
             display_data[i] = word ( ( i + 1 ), 0x0F );
            break;
        display_the_numbers();
        add_flag = 1;
        keystate = 0;
        // Over Flow
        over_flow = 1;
        digit_number[0] = 0;
        display_data[0] = 0x010B;
        for ( int i=1;i<8;i++)
           digit_number[i] = 0;
           display_data[i] = word( (i+1), 0x0F );
        keystate = 0;
Here the complete code:
   Calculator Version 1.0
   Just add a number enter by the keypad and display it.
   With 2 function : Add / Equal ===> * button
                     Clear ==>  # button
   It will use a MAX7219 for display the data ( for the shiftOut() ).
   and a 4021 for the keypad input data with the use of
   an NOT gate 74HC14. ( for the shiftin() )
   See the keypad example in the tread for details.
   The interrupt use a 72LS20 from the row pins, any LOW signal will
   produce a HIGH pulse to be use has an interrupt signal.
   By Serge J Desjardins
   aka techone / tech37
   Toronto, Ontario, Canada
   Compile and Tested.
   Bug :
   The add section need to be re-code.
// Keypad Serial pins
const byte latchkeypin = 10;
const byte datakeypin = 12;
const byte clockkeypin = 11;
// Display Serial pins
const byte datadisplaypin = 9;
const byte clockdisplaypin = 8;
const byte latchdisplaypin = 7;
// Anykey and interrupt pin
const byte anykeypin = 2;
// MAX7419 init data
word initdata[5] = { 0x0C01, 0x0F00, 0x0A0B, 0x0B07, 0x09FF };
// Fill the Display array with a blank code
word display_data[8] = { 0x0100, 0x020F, 0x030F, 0x040F, 0x050F, 0x060F, 0x070F, 0x080F };
// The digit array
byte digit_number[8] = {0,0,0,0,0,0,0,0};
// For the digits extraction calculation
long power_of_ten[8] = {1,10,100,1000,10000,100000,1000000,10000000};
// Key press keypad flag
volatile boolean keystate;
// Overflow flag
boolean over_flow;
// add button flag
boolean add_flag;
// Clear button flag
boolean clear_flag;
// The keypad data
byte keydata;
byte keynumber;
// the ADD calculation
long the_number;
long temp_number;
long add_number;
  //start serial
  //Serial.begin(9600);
  //define the pins modes
  pinMode(latchkeypin, OUTPUT);
  pinMode(clockkeypin, OUTPUT);
  pinMode(datakeypin, INPUT);
  pinMode(datadisplaypin, OUTPUT);
  pinMode(clockdisplaypin, OUTPUT);
  pinMode(latchdisplaypin, OUTPUT);
  pinMode(anykeypin, INPUT);
  // setup the interrupt pin
  attachInterrupt(0,anykeypress,RISING);
  /* Init the MAX7419 : Normal Mode
                        Normal Operation
                        Setting the Intensity
                        Numbers of Digits being display
                        Set to Decode Mode
  for (int i=0;i<5;i++)
     digitalWrite(latchdisplaypin, LOW);
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, highByte(initdata[i]));
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, lowByte(initdata[i]) );
     digitalWrite(latchdisplaypin, HIGH);
     delay(5);
  // Blank the display
  // init the flags and the calculation variable
  keystate = 0;
  add_number = 0;
  add_flag = 0;
  over_flow = 0;
  clear_flag = 1;
  while ( keystate == 0)
     // wait for a key press
  read_keypad();
  convert_the_keypad_data();
  // reset add flag and set the display
  if ( (( add_flag == 1) || ( clear_flag = 1 )) && ( over_flow == 0 ) )
      display_data[i] = word ( ( i+1 ), 0x0F );
    add_flag = 0;
    clear_flag = 0;
  // Enter the numbers routine
  if ( ( keynumber < 0x0A ) && ( over_flow == 0 ) )
     // Enter the key number and move the arrays data.
     for (int i=7;i>0;i--)
       digit_number[i] = digit_number[i-1];
       display_data[i]=display_data[i-1];
       display_data[i] = word ( (i+1) , lowByte( display_data[i] ) );
     digit_number[0] = keynumber;
     display_data[0] = word ( 1, keynumber );
     keystate = 0;
      the_number= 0;
            break;
        add_flag = 1;
        keystate = 0;
        // Over Flow
        over_flow = 1;
        keystate = 0;
    // Check for the "Clear" button
    if ( keynumber == 0x0E )
      display_data[0] = 0x0100;
      add_number = 0;
      keystate = 0;
      over_flow = 0;
      add_flag = 0;
      clear_flag = 1;
  //For troubleshooting the program using Serial Monitor
    Serial.print(keydata, BIN);
    Serial.print("  ");
    Serial.print(keydata, HEX);
    Serial.print("  ");
    Serial.print(keynumber, HEX);
    Serial.print("  ");
    Serial.println(keydata, DEC);
// Read keypad data via a 74HC14 - Inverter from the 4021
void read_keypad()
  digitalWrite(latchkeypin,HIGH);
  delayMicroseconds(20);
  digitalWrite(latchkeypin,LOW);
  keydata = shiftIn(datakeypin, clockkeypin,LSBFIRST);
// Convert the keypad data into BCD
// And a code for *, 0, # button
void convert_the_keypad_data()
  byte what_row;
  what_row = ( keydata >> 3) & 0x0F;
  switch ( what_row)
    case 1:
           keynumber = ( ( keydata >> 1 ) & 0x03 ) + 1;
           break;
    case 2:
           keynumber = (( keydata >> 1 ) & 0x03 ) + 4;
           break;
    case 4:
           keynumber = (( keydata >> 1 ) & 0x03 ) + 7;
           break;
    case 8:
           special_key();
           break;
// the display the data routine to the MAX7219
void display_the_numbers()
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, highByte(display_data[i]) );
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, lowByte(display_data[i]) );
     delay(5);
// A special code for 0, *, # button
void special_key()
   byte special_case;
   special_case = ( ( keydata >> 1) & 0x03 ) + 1;
   switch ( special_case )
     case 1:
            keynumber = 0x0E;
            break;
     case 2:
            keynumber = 0x00;
            break;
     case 3:
            keynumber = 0x0B;
            break;
// Interrupt Routibe
void anykeypress()
  keystate = 1;
should the arrays not be [7] here?i think the last one is free.
array -> 7 ? No... 8 "Boxes" :wink: from Box 0 to Box 7 = 8 boxes
The arrays need data into them. I init my arrays, even it is Zero's. The code need it. I always init my variables.
My full calculator code is compiling. A bug in the Add section, an execution bug. I need to check it out, and maybe re-code that section.
The problem with me when I code, I have "writter's block". My mind is just "blank" and I have no clue how can I do this, and it is the lack of ideas of how can I program this out. That what I call "Writter's block".
Why don't you just form specific functions for specific tasks like for e.g. >> Add() function for adding and pass on the processed variables(after formulating them for unit place etc.) into the respective function after just checking the * for Add or equal button .
I think one reason you have a bug is that there is just too much going on in the one function. As Nis$hant inferred you should compartmentalise things.
Also I don't think you need all the array shuffling and IMO read_keypad() should return a human-readable value, ie 0-9 and + etc.
For example here's is a simpler way (I think)
long num1;
long num2;
long result;
long *curr_num = num1;
byte key;
loop () {
	key = read_keypad();	// this should return an int == to the numeric key entered or obvious values for '=' etc
	switch (key) {
		case '+':
		    if (curr_num == num1) {	// if first number just start accululating into second number
				curr_num = num2;
				addNumbers();		// if the second number add them
			break;
		case '=':
			addNumbers();
			break;
		default:
			accumulateNumber();
			display_number(curr_num);
void addNumbers () {
	result = num1 + num2;
	display_number(result);
	curr_num = num1;
	num1 = 0;
	num2 = 0;
void accumulateNumber () {
	*curr_num *= 10;
	*curr_num += key;
void display_number(long * num){
	for (int x = 0; x < 8, x++) {
		shiftNum (num % 10);	// send digit out
		num /= 10;
This is little more than psuedo code and there's no error checking etc but I think it's easy to follow and if there's a bug it should be easy to isolate.
Rob
Yes Sir ROB i used to do similar coding while i programmed addition/subtraction/division/multiplication calculator back 2 years from now in VB.
The approach is pretty simple and easy to grasp while Mr. Serje may not have any fault in his programme but due to increased cluttering he might not be able to stay on the correct logical path.
@Graynomad
Thanks for your idea. I may change my code if I have issues. Oh yes... I still do... will change the code later.
@NI$HANT
I agree with you. I may have to change my code for a modular method of coding. I have to many if()'s. I will have to do that later.
Updated :
I did re-code the add section, no modular method yet. Still have an issues with the keypad. I have : Double entry and wrong entry. All intermittents problems. I may have to re-design the keypad circuit. Right now, it is not reliable.
As for the code, after the Add section change, still some bugs... But I like the new methode of adding. Just like :
Carry : 1111
1234 <-- Array call : digit_number[]
  • 9876 <-- Array call : add_number[]
Last Digit ->11110 The last digit is the OverFlow. So I add two array + the carry. That is the logic behind the Add routine.
The section that work : entry routine, the clear routine, keypad routine, convert routine and the display routine.
I will use the Serial Monitor to see what is going on.
The updated code is the next post.
Thank for the idea. I will apreaciated that you guys check my code.
Here my updated code :
   Calculator Version 1.5
                     Clear ==>  # button
   Compile and Tested.
// The digit array
// The second array - The total number
byte add_number[9] = {0,0,0,0,0,0,0,0,0};
// Overflow flag
boolean over_flow;
// add button flag
boolean add_flag;
boolean clear_flag;
// The keypad data
byte keydata;
byte keynumber;
  //start serial
                        Normal Operation
                        Set to Decode Mode
     delay(5);
  keystate = 0;
  add_flag = 1;
  over_flow = 0;
  clear_flag = 1;
  read_keypad();
     if ( ( add_flag == 1) && ( clear_flag = 1 ) )
     add_flag = 0;
     clear_flag = 0;
     keystate = 0;
         add_number[i] = add_number[i+1] + add_number[i] + digit_number[i];
         if (add_number[i] > 0x09 )
           add_number[i+1] = 1;
           display_data[i] = word ( ( i + 1 ), ( add_number[i] - 10 ));
            display_data[i] = word ( ( i + 1 ) , add_number[i]);
      // check for over flow
      if ( add_number[8] > 0)
        over_flow = 1;
        keystate = 0;
        over_flow = 1;
        add_flag = 1;
        keystate = 0;
        over_flow = 0;
        add_flag = 1;
      add_number[0] = 0;
        add_number[i] = 0;
      add_number[8] = 0;
      keystate = 0;
      over_flow = 0;
      add_flag = 1;
      clear_flag = 1;
    Serial.print("  ");
    Serial.print("  ");
    Serial.print("  ");
void read_keypad()
  byte what_row;
  switch ( what_row)
    case 1:
           break;
    case 2:
           break;
    case 4:
           break;
    case 8:
           special_key();
           break;
     delay(5);
void special_key()
   byte special_case;
     case 1:
            keynumber = 0x0E;
            break;
     case 2:
            keynumber = 0x00;
            break;
     case 3:
            keynumber = 0x0B;
            break;
void anykeypress()
  keystate = 1;
Updated :
I did place the sections into a routine way. I re-modify my code. Almost the same code, except a bit more "modular"
Issue : The Add section still give me some problems. Sometime, it work, and then it is not, I even see the Over Flow ==> E the Numbers are lock and the add button is lock <== That is expected, that mean it did go through the Add Section. The clear work just great. Still have double entry, and I got the feeling my keypad circuit need to be change. The cause is : When I press a key, the voltage level is not approaching a LOW level for the input of the 74HC14. It is in the "If Zone" <-- "Can Not Make Up It Mind Level". So I will re-design the keypad circuit with LM339, and add a 555 circuit in a monostable mode to take care of the interrupt signal <-- possible cause of the "double" entry. The interrupt signal came from a 74LS20. The 555 is the "deboucing" circuit. And also, I may add a latch chip between the 74LS14 ( that is the buffer after the LM339 output ) and the 4021. Maybe the 555 output ? , or another digital out pin to take care of that ? 555 is a more reliable.
As for my code, I will keep it and test it with the new keypad circuit. Well I may change a bit the Add section... I press Add, and it display : 0000012 . That is just cosmetic bug, I will fix that in the Add section. Just replace the 0 before the 1 with 0x0F <-- code for Display Blank to be send at the MAX7219.
I know, it is sound overkill, I need reliability, that is why I overkill in my circuits and code. I am trying to remove Murphay's Law of the equation. Input + Murphay's Law = Garbage Output
Next post is the updated code.
Here the updated code. I will appreaciated that you guys look at it and tell me what you think.
                     Clear ==>  # button
   Compile and Tested. Still Issues. Maybe it it the Keypad circuit. Not so clean
// The digit array
// Overflow flag
boolean over_flow;
// add button flag
boolean add_flag;
boolean clear_flag;
// The keypad data
byte keydata;
byte keynumber;
// The choice
byte choise;
  //start serial
                        Normal Operation
                        Set to Decode Mode
     delay(5);
  keystate = 0;
  add_flag = 1;
  over_flow = 0;
  clear_flag = 1;
  read_keypad();
  // The choise 1 = numbers , 2 = add , 3 = clear
  switch (choise)
     case 1 :
             entry_of_numbers();
             break;
     case 2 :
             add_section();
             break;
     case 3 :
             clear_section();
             break;
// Choise 1
void entry_of_numbers()
  if ( over_flow == 0 )
     add_flag = 0;
     clear_flag = 0;
     keystate = 0;
// Choise 2 - the add section
void add_section()
         if ((add_number[i] > 0x09) && (add_number[i] < 0x14) )
      if ( add_number[8] != 0)
        over_flow = 1;
        keystate = 0;
        over_flow = 1;
        add_flag = 1;
        keystate = 0;
        over_flow = 0;
        add_flag = 1;
// Choise 3 - The clear section
void clear_section()
      add_number[0] = 0;
        add_number[i] = 0;
      add_number[8] = 0;
      keystate = 0;
      over_flow = 0;
      add_flag = 1;
      clear_flag = 1;
    Serial.print("  ");
    Serial.print("  ");
    Serial.print("  ");
void read_keypad()
  byte what_row;
  switch ( what_row)
    case 1:
           choise = 1;
           break;
    case 2:
           choise = 1;
           break;
    case 4:
           choise = 1;
           break;
    case 8:
           special_key();
           break;
     delay(5);
void special_key()
   byte special_case;
     case 1:
            keynumber = 0x0E;
            choise = 3;
            break;
     case 2:
            keynumber = 0x00;
            choise = 1;
            break;
     case 3:
            keynumber = 0x0B;
            choise = 2;
            break;
void anykeypress()
  keystate = 1;
Hi Mr.Serje , had a look on the code,
What about the KeyPad , is it working fine with amp now? i recall you had a problem with that! , May be its having debouncing effect?
One thing notice is that there's no debouncing with the keypad reading. That may cause unreliable input.
Rob
I agree with both of you. I may add a debounce, but I wonder how and where to place the tiny delay ? The key data came from the 4021, after a shiftIn() read. And the interrupt signal came from a 4 input NAND gate - 74LS20. So any bouncing by a key, also created a double pulse at the interrupt pin, activate the interrupt request. A 555 in monostable mode will take care of that. I will re-design the keypad circuit and is not done yet. I may add a latch in between the inverters and the 4021. And beside the bouncing problem, the close contact is not a close contact after all, more than intermittent, due to a non - proper LOW level at the input gates. The LM339 comparator will take care of that. I will set the comparator V ref at 2.5 V <-- mid point. Still two state.
I will keep you guys posted.
I happen to have a PS/2 keypad - see picture. I will re-code using the PS/2 library and re-do a circuit to use the PS/2 keypad and using the same 7 segments display. I will do that later. I will keep you posted on that one too. Still keep the same tread anyway.
Hi Mr.Serje i hope things are fine and the code is hopefully getting done ,following i add my suggestions:
I think what here can be done is that as the interrupt is being fired by the NAND gate You can set a counter in here to note the number of times the interrupt routine is being fired and put in a debugging statements on the Serial (I debugged my code in the same way when I was working with interrupts that however came from a mechanical part that is a Reed Switch) this way the real culprit can be traced back, if and only if the debouncing may be happening.
also. Mr.Serje you told once that amplifying(if i recall it right from my memory) the keypad buttons may make then susceptible to ultra sensitivity and thus the same can result in debounce.
I have a keypad/LCD screen that I put both debounce code into it for the usual reasons. I also put a millis count so that I could not double enter the same button.
Pseudo code:
Check for button press twice for debounce
          if good button press, use it,
  if a new button press check millis
 if (millis - last button press) ==  long enough time
  record new button press
The downside is you can push a button too quickly and have it ignored depending how you set the "long enough time variable.
@cyclegadget
Thank for you tips. Using the millis - time to check if a double press is being done... OK I think I get you. To impliment in my code, that I will figure this out. It look like it is a good idea. I will impliment something like that.
Let see :Loop 1 : read key Loop 1 ---> I mean : void loop()
measured time
Loop 2 : readkey
measured time
check the time difference
if to small - don't take the key
if big enough - take the key
Something like that. But with a 555 in monostable - output of the 555 going to the interrupt pin will solve the debouncing problem.
And I will do a digitalWrite( latchkeypin, HIGH ) in the interrupt routine to latch the keypad data.
@NI$HANT
To monitor the interrupt routine using Serial Monitor is a good idea.
I agree. That the 555 in monostable come in. I just set the output of the 555 about .. let say 10 mS to 20 mS. The input can multi pulse for 1 ms to 8 mS until it is stable, and the 555 chip won't even care about it. It is after the 555 finish it's pulse that the 555 chip care. ( the mono stable circuit, that is )
Updated :
The new keypad circuit is still no done. Today, when I was finish my afternoon run, going home, and in the kitchen, I was thinking about my code, and it occur to me that I made a executable bug in the ADD routine. I was installing the carry into the next array box, that may explain some garbage data in my display. No add right , screw up numbers, etc. Instead to place the carry into the add_number[] array, I just simply use a "temp" variable. Use the / and % to isolate the unit number.
Example : temp = add_number / 10; <-- the carry calculation
  • temp = 12 / 10 --> 1 or 8 / 10 --> 0 *
    Extract Unit : add_number = add_number % 10;
    add_number = 12 % 10 --- > 2 or 8 % 10 ---> 8 <-- the unit to be display.
    Add also, I fix the "cosmetic" bug. Was display : 00001234 Now : 1234
    I change the interrupt routine : I just add : digitalWrite(latchkeypin, HIGH); And remove that line from the read_keypad routine.
    *Next post is the new and final code. <-- I think *
    Here the old code :
    *_</em></em> <em><em><em>*if ( over_flow == 0)     {            for (int i=0;i<8;i++)       {         add_number[i] = add_number[i+1] + add_number[i] + digit_number[i];         if (add_number[i] > 0x09 )         {           add_number[i+1] = 1;           display_data[i] = word ( ( i + 1 ), ( add_number[i] - 10 ));         }         else         {             display_data[i] = word ( ( i + 1 ) , add_number[i]);         }              }              // check for over flow       if ( add_number[8] > 0)       {              over_flow = 1;         digit_number[0] = 0;                display_data[0] = 0x010B;         for ( int i=1;i<8;i++)         {           digit_number[i] = 0;           display_data[i] = word( (i+1), 0x0F );                      }              keystate = 0;         over_flow = 1;         add_flag = 1;              display_the_numbers();                }       else       {         keystate = 0;         over_flow = 0;         add_flag = 1;         display_the_numbers();       }          }*</em></em></em> <em><em>_*
The new Add section
*_</em></em> <em><em><em>*// Choise 2 - the add section void add_section() {     byte temp;       if ( over_flow == 0 )     {       // The Add logic        temp = 0; // the carry variable       for (int i=0;i<8;i++)       {         add_number[i] = temp + add_number[i] + digit_number[i];         temp = add_number[i] / 10;         add_number[i] = add_number[i] % 10;         display_data[i] = word ( ( i + 1 ) , add_number[i] );       }              // check for over flow       if ( temp != 0)       {              over_flow = 1;         digit_number[0] = 0;                display_data[0] = 0x010B;         for ( int i=1;i<8;i++)         {           digit_number[i] = 0;           display_data[i] = word( (i+1), 0x0F );                      }              keystate = 0;         over_flow = 1;         add_flag = 1;              display_the_numbers();                }       else       {         /*         For a cleaner display by removing         the zero's on the left side of the number         */         for (int i=7;i>0;i--)         {           if (add_number[i] == 0)           {             display_data[i] = word ( ( i + 1 ) , 0x0F );           }           else           {             break;           }                  }                  keystate = 0;         over_flow = 0;         add_flag = 1;         display_the_numbers();       }          } }*</em></em></em> <em><em>_*
Here is the updated and maybe the final code. It is working nice, except the issue with the keypad - double entry and miss key.
   Calculator Version 2.0
                     Clear ==>  # button
   Compile and Tested.
// The digit array
byte add_number[8] = {0,0,0,0,0,0,0,0};
// Overflow flag
boolean over_flow;
// add button flag
boolean add_flag;
boolean clear_flag;
// The keypad data
byte keydata;
byte keynumber;
// The choice
byte choise;
                        Normal Operation
                        Set to Decode Mode
     delay(5);
  // Set the latch key LOW
  digitalWrite(latchkeypin, LOW);
  keystate = 0;
  add_flag = 1;
  over_flow = 0;
  clear_flag = 1;
  read_keypad();
  switch (choise)
     case 1 :
             entry_of_numbers();
             break;
     case 2 :
             add_section();
             break;
     case 3 :
             clear_section();
             break;
// Choise 1
     add_flag = 0;
     clear_flag = 0;
     keystate = 0;
void add_section()
    byte temp;
      // The Add logic
      if ( temp != 0)
        over_flow = 1;
        keystate = 0;
        over_flow = 1;
        add_flag = 1;
            break;
        keystate = 0;
        over_flow = 0;
        add_flag = 1;
      add_number[0] = 0;
        add_number[i] = 0;
      keystate = 0;
      over_flow = 0;
      add_flag = 1;
      clear_flag = 1;
void read_keypad()
  delayMicroseconds(10);
  byte what_row;
  switch ( what_row)
    case 1:
           choise = 1;
           break;
    case 2:
           choise = 1;
           break;
    case 4:
           choise = 1;
           break;
    case 8:
           special_key();
           break;
     delay(5);
void special_key()
   byte special_case;
     case 1:
            keynumber = 0x0E;
            choise = 3;
            break;
     case 2:
            keynumber = 0x00;
            choise = 1;
            break;
     case 3:
            keynumber = 0x0B;
            choise = 2;
            break;
void anykeypress()
  keystate = 1;
