I am trying to control the 4wd car with 3 ping sensors, I was able to integrate and the three sensors and read the information out of them, but when I put the commands to move the car, the first sensor always read 0 while the others read the real distance. Can you tell me why this is happening?
the code is below
#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_64KHZ);
AF_DCMotor motor3(3, MOTOR12_1KHZ);
AF_DCMotor motor4(4, MOTOR12_1KHZ);
int trigPin []={8,10,12};
int echoPin []={9,11,13};
int i, j;
char *names[]={"Right ", "Front ", "Left "};
Serial.begin (9600);
motor1.setSpeed(200); // Set the speed for the motors (255 is the maximum)
motor2.setSpeed(200);
motor3.setSpeed(200);
motor4.setSpeed(200);
void forward(){ // This function moves the wheels forward
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void backward() { // This function moves the wheels backward
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void haltMotors() // This function stops each motor (It is better to stop the motors before changing direction.)
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void turnRight(){ // This function turns the robot right.
void turnLeft(){
unsigned long ping(int j) {
int duration;
pinMode (trigPin[j], OUTPUT);
pinMode (echoPin[j], INPUT);
digitalWrite(trigPin[j], LOW);
delayMicroseconds(5);
digitalWrite(trigPin[j], HIGH);
duration = pulseIn(echoPin[j], HIGH);
return (duration/2) / 29.1;
int smallest_value (unsigned long array[3]){ // function to find the smallest value int the array
int min_value, n;
min_value=array[0];
for (n=1; n<3; n++){
if(array[n]<min_value){
min_value=array[n];
return min_value;
int pos (unsigned long array[3]){ // function to find position of the smallest value in the array
int min_value, poS, n;
poS=0;
min_value=array[0];
min_value=array[n];
poS=n;
return poS;
void loop(){
int l, minimum, Position;
unsigned long distance[3];
for (i=0, l=0; i<3, l<3; i++, l++){
distance[l]=ping(i);
Serial.print (names[i]);
Serial.print(distance[l]);
Serial.print("cm");
minimum=smallest_value(distance);
Position=pos(distance);
Serial.print (minimum);
Serial.print (Position);
delay (1000);
if (minimum>10){
forward();}
else if (minimum<10 && Position==0){ //if the smallest value is smaller than 10 and the position is 0 (right)
turnLeft();}
else if (minimum<10 && Position==2){
turnRight();}
else if(minimum <10 && Position==1){
haltMotors();}
those two values are the smallest value on the array distance and the position of this smallest value on the same array I use those values to move the robot, if the smallest value is on the position 0 of the array the robot will turn left
I solved part of the problem by putting a if statement before the movement part
if (minimum!=0){
if (minimum>10){
forward();}
turnLeft();}
turnRight();}
haltMotors();}
but it gave me this type of result
Right 0cm
Front 34cm
Left 68cm
0
0
Right 70cm
Front 35cm
Left 67cm
35
1
Right 0cm
Front 35cm
Left 68cm
0
0
Right 70cm
Front 34cm
Left 53cm
34
1
int min_value, n;
min_value=array[0];
min_value=array[n];
return min_value;
Why does a function that finds the smallest value in an array of unsigned longs store that value in an int, and why does it return an int?
poS=0;
min_value=array[0];
min_value=array[n];
poS=n;
return poS;
Another function that stores unsigned longs in ints, and expects that to work. It won't.
Would this be a simpler way of finding the smallest of three?
unsigned long smallest_value (unsigned long array[3])
return min (array [0], min (array [1], array [2]));
poS=0;
I'm not keen on variable/function names that differ only in case (pos and poS).
I made the modifications you suggested, but it is still doing the same thing. Anyone know why the sensor alternates the reading between 0 and the real value? That's the real problem with the program.
int i, j;
void turnLeft(){
int duration;
unsigned long smallest_value (unsigned long array[3]){ // function to find the smallest value int the array
unsigned long min_value;
int n;
min_value=array[0];
min_value=array[n];
return min_value;
poS=0;
min_value=array[0];
min_value=array[n];
poS=n;
return poS;
void loop(){
int l, minimum, Position, count;
Serial.print("cm");
delay (1000);
if (minimum!=0){
if (minimum>10){
forward();}
turnLeft();}
turnRight();}
haltMotors();}
else {
count=0;}
yeah it makes sense, I don't need the 2 variables. I changed but I'm still getting the same problem.
int i, j;
void turnLeft(){
int duration;
int n;
min_value=array[0];
min_value=array[n];
return min_value;
poS=0;
min_value=array[0];
min_value=array[n];
poS=n;
return poS;
void loop(){
Serial.print("cm");
Serial.print ("Smallest value ");
Serial.print ("position of smallest ");
delay (1000);
if (minimum!=0){
if (minimum>10){
forward();}
turnLeft();}
turnRight();}
haltMotors();}
else {
count=0;}
the output that I get is
Right 55cm
Front 57cm
Left 75cm
Smallest value 55
position of smallest 0
Right 0cm
Front 49cm
Left 74cm
Smallest value 0
Right 54cm
Front 46cm
Left 73cm
Smallest value 46
position of smallest 1
Right 0cm
Front 44cm
Left 73cm
Smallest value 0
int i, j;
void turnLeft(){
int duration;
int n;
min_value=array[0];
min_value=array[n];
return min_value;
poS=0;
min_value=array[0];
min_value=array[n];
poS=n;
return poS;
void loop(){
int minimum, Position, count;
for (i=0; i<3; i++){
distance[i]=ping(i);
Serial.print(distance[i]);
Serial.print("cm");
delay (1000);
if (minimum!=0){
if (minimum>10){
forward();}
turnLeft();}
turnRight();}
haltMotors();}
else {
count=0;}
Right 55cm
Front 69cm
Left 77cm
Smallest value 55
Right 0cm
Front 56cm
Left 76cm
Smallest value 0
Right 55cm
Front 52cm
Left 76cm
Smallest value 52
Right 0cm
Front 48cm
Left 76cm
Smallest value 0
Instead of making two passes through the array, to find the minimum value and the location of the minimum value, you can just find the index to the smallest position, and then read the value in that position.
It would be worth putting some more Serial.print() statements in. What value is passed to the ping() function?
The ping() function is a little strange, too. It is defined as returning an unsigned long, when, in reality, the value being returned is an int that is valued as a result of a float calculation. Consistency is a good thing.
