Hi, does anyone know if it is possible configuring the IDE to display RAM Memory usage after compilation for the M0(Zero, SAMD21). Like it is done for ESP8266 and AVR based boards.
For AVR boards you get a message like this after compilation:
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
For ESP8266 boards it looks like this:
Minimum Memory Usage: 32100 bytes (39% of a 81920 byte maximum)
I have seen previous posts showing how to get this info during runtime by using methods given at:
But, it would be much more convenient having it displayed after compilation, together with program memory usage(which is displayed for all boards).
For my Arduino IDE, the "platform.txt" file is located:
C:\Portable\Arduino-183A\portable\packages\arduino\hardware\samd\1.6.15\platform.txt
This works for Arduino IDE and Micro Visual. Following is and example of what is displayed after compile(verify):
text data bss dec hex
10840 272 1936 13048 32f8
Where:
text = Program FLASH memory
data = Is used for initialized data. This is best explained by adding the following (global/extern) variable to a program. It will increase ‘data’ by 4 bytes: int32_t myVar = 0x12345678;
It counts for RAM and FLASH. The linker allocates the data in FLASH which then is copied from ROM to RAM in the startup code.
bss: The ‘bss’ contains all the uninitalized data. This is what ends up in RAM.
