v 1.8.9
Im trying to install this version of the IDE on a raspberry pi 3 64 with the raspbian OS, which appears to be a version of Debian. it has the GPU set at 128. I follow the instructions, that is, download the compressed file, extract a tar that gets extracted into the files, I run the ./install.sh, and then it has two errors:
pi@raspberrypi:~/Downloads/arduino-1.8.9 $ ./install.sh
Adding desktop shortcut, menu item and file associations for Arduino IDE...
rm: cannot remove '/usr/local/bin/arduino': Permission denied
Removing symlink failed. Hope that's OK. If not then rerun as root with sudo.
ln: failed to create symbolic link '/usr/local/bin/arduino': File exists
Adding symlink failed. Hope that's OK. If not then rerun as root with sudo.
done!
So when I click on the icon, it doesnt do anything.
Ive tried this with sudo, sudo -i to address the permission issue, same thing.
Can anyone advise what I am doing wrong ? (BTW did install it on a windows 10 laptop, no problem).
Many grateful thanks from me and my son.
