I have 2 Aneng DMMs, as everybody knows, they are cheap multimeters, the problem is that they come with much cheaper test leads. I'd like to get at least a better pair.
I already have the mini-grabbers, a test clip for smd, only that it's not a normally closed, it's like a tweezers, you have to hold it close, and crocodile clips, all are finished with plugs to connect directly on the dmm.
Unless I'm just probing something (that's the point of the probes, right I use the mini-grabbers all the time.
I take that in your opinion a 'better' pair of probes is always in order, even when the dmm is not that good.
I still have my 25 yo analog Kiotto meter, comparing to the aneng probes, those are very good, however the rubber inserts are too thick and too short, they don't feet in a modern meter.
