Hi guys,
So I'm a noob when it comes to the electrical side of these things (I'm a programmer so I'm venturing on fresh turf!). Basically I'm trying to build a quadruped with 12 servos, I've connected them up to a Sensor Shield Expansion Board V5 that sits on top of the Arduino Uno (i.e. the pins plug directly into it).
Thing is, when I run some code from this site, the servos move in a twitchy way, and the usb continuously disconnects and reconnects.
I'm assuming this is some kind power issue - I'm only connecting the Uno via a USB port but I also tried adding a 9V battery with no luck... Not sure how to make this go smoothly.
This was where I was copying the structure from. ATM I've only got the servos, shield and Uno connected up.
Any help would be appreciated - thanks!
